Install HASS on Raspberry Pi 2
I have installed the HASS system via this guide from the HASS website youtube.com/watch?v=GjzOXkPb7XE
I have installed this and rebooted and tried to start it manually without luck, I copied a working config from my other HASS (in docker on an unraid box, I cant forward serial so I am moving it)… I am lost
[code]pi@raspberrypi:~ $ sudo service hass-daemon status
● hass-daemon.service - LSB: Home\ Assistant
Loaded: loaded (/etc/init.d/hass-daemon)
Active: active (exited) since Wed 2016-03-23 14:56:06 PDT; 13min ago
Process: 460 ExecStart=/etc/init.d/hass-daemon start (code=exited, status=0/SUCCESS)
Mar 23 14:56:05 raspberrypi hass-daemon[460]: Starting service…
Mar 23 14:56:05 raspberrypi su[464]: Successful su for root by root
Mar 23 14:56:05 raspberrypi su[464]: + ??? root:root
Mar 23 14:56:05 raspberrypi su[464]: pam_unix(su:session): session opened for user root by (uid=0)
Mar 23 14:56:06 raspberrypi hass-daemon[460]: Service started
Mar 23 14:56:06 raspberrypi systemd[1]: Started LSB: Home\ Assistant.
Mar 23 15:00:26 raspberrypi systemd[1]: Started LSB: Home\ Assistant.
Mar 23 15:06:54 raspberrypi systemd[1]: Started LSB: Home\ Assistant.
Mar 23 15:06:56 raspberrypi systemd[1]: Started LSB: Home\ Assistant.
Mar 23 15:06:57 raspberrypi systemd[1]: Started LSB: Home\ Assistant.
Mar 23 15:06:58 raspberrypi systemd[1]: Started LSB: Home\ Assistant.
Mar 23 15:06:59 raspberrypi systemd[1]: Started LSB: Home\ Assistant.
pi@raspberrypi:~ $
[/code]
The HASS log in empty
pi@raspberrypi:~ $ tail /var/opt/homeassistant/home-assistant.log pi@raspberrypi:~ $
Any errors when running without the daemon?
$ hass
I am having the same problem on raspberry pi 3.
It worked perfectly until yesterday, today suddenly stopped to work.
hass without daemon options works all right.
I have found a walk around using systemd instead.
However this problem remains very odd to me.
