hoatienii
(Hoatienii)
1
How can i install hassio on docker, my docker run on openwrt.
I follow this to install home assistant
> $ docker run --init -d --name="home-assistant" -e "TZ=America/New_York" -v /PATH_TO_YOUR_CONFIG:/config --net=host homeassistant/home-assistant
> It
successfull but no hassio tab.
please help!
Thanks!
nickrout
(Nick Rout)
2
That is home-assistant, not hassio.
You haven’t installed HassIO, you installed Home-Assistant, as far as I can tell.
To install HassIO, you can follow this gist.
nickrout
(Nick Rout)
4
But not for openwrt I think.
There was an openwrt thread around - not sure whether it ended up installing hass or hassio.
This is the thread i was thinking of How to install HA on your router
hoatienii
(Hoatienii)
5
thanks! but my docker run on openwrt, cannot use this command.
