I decided to convert an old Mac Mini into a server and wanted to get home assistant up and running. I thought I would document the process in the hope it helps others in the community.
I’ve posted the full write up on how to install Home Assistant in Virtualbox here. Each step of the process is documented so that even those who are not super tech-savvy can follow along.
I have moved this to the “Share Your Projects” topic.
Community guides require the full text of the guide in the first post, not a link to an external site. This is so that anyone can update the guide if it becomes out of date (like a wiki).
Community Guides
The Community Guides section is a place to share guides/tutorials with our community. Every post/topic in this section works like a Wiki and can be edited and improved by anybody.
Please note, guides provided in this section may be outdated/broken and are not supported by Home Assistant. Use these at your own risk.
If you edit your post and provide the full text I can move it back.
Well written and very thorough with great screen shots. I already run VB on a dedicated Win 10 PC, but this really has me reconsidering a move to Debian as the host to squeeze more power out of it. Thanks.
Thanks for the suggestion @tom_l, that’s a good point you have raised and something I’d overlooked. I will get it updated (time permitting) in the coming days.
Also clearly point out the real network interface should be bridged, and NOT the VirtualBox-Host-only (a mistake often made as many people don’t understand how it works)
Dumb user here. I’m having some issues with my NUT ups addon failing with usb permissions. Sometimes it works, sometimes it doesn’t. I have a usb filter defined by the manufacturer id only. I have the virtualbox extension installed. How do I go about executing the sudo adduser $USER vboxusers command from ssh? I have the terminal addon installed in HA. I think I’m missing a step, I keep getting sudo command not found error.
