Install Home Assistant, Mosquitto broker and Node-Red on android
Thank you for a very nice guide. Excellent idea to use an old android phone. Have followed yr guide and even been able to upgrade HA to 0.65.1.
Now trying to use the IKEA Tradfri components but it fails to install with error msg:
Blockquote
Unable to install package pytradfri[async]==4.1.0: Command “/data/data/com.termux/files/usr/bin/python -u -c “import setuptools, tokenize;file=‘/data/data/com.termux/files/usr/tmp/pip-build-rdba6avw/DTLSSocket/setup.py’;f=getattr(tokenize, ‘open’, open)(file);code=f.read().replace(‘\r\n’, ‘\n’);f.close();exec(compile(code, file, ‘exec’))” install --record /data/data/com.termux/files/usr/tmp/pip-w6ijtvvu-record/install-record.txt --single-version-externally-managed --prefix --compile --user --prefix=” failed with error code 1 in /data/data/com.termux/files/usr/tmp/pip-build-rdba6avw/DTLSSocket/
Being new into HA this is far above my capability. Read in this thread:
that a recompilation of python might help. but before going down this path I give it a try here in the hope that someone could offer an alternative solution for this env.
Many thanks
