your DS218+ supports docker. So copy your config directory to a shared folder on your Synology, install the Docker package, download the HA container image, setup the container using the gui, command line, or docker-compose and you’ll have the basic HA install going. If you have other things like SSL, Z-Wave, etc then you’ll have a little more advanced setup that requires setting up the container from the command line or docker-compose.
Thanks for the quick reply. Yeah the issue I’m worried about is how to map the USB Z-Wave/Zigbee stick. I have been using HA for 2 years now but with a RP3 I have all the documentation that got me going but moving off a Pi I think I may be out on a limb…
when you plug the USB Z-Wave stick into the Synology you’ll get a path such as /dev/ttyACM0. You run the HA docker container with the command --privileged which gives the docker container root access to /dev or you can specifically map the device to the container with --device=/dev/ttyACM0. then put usb_path: /dev/ttyACM0 under the zwave: section of your configuration.yaml and you should be all set with Z-Wave.
EDIT: if you have multiple USB devices, you may want to look into creating symlinks to the actual devices. Something like /dev/zwave which is mapped by VID/PID to the appropriate device path regardless if it is /dev/ttyACM0 or /dev/ttyACM1, etc. That way when things reboot or reload for any reason, the USB sticks are always mapped correctly.
Thanks for this. I just rebuilt my HA Docker after being away from the community for some time and forgot this detail. I’ll add this to the doco now too to help others.
