Install is Unstable (Software and Hardware) Need assistance!
Long story short: I have wiped and put a fresh install of hassio on a raspberry pi 2 (first gen) and everything seemed to be just fine (listed below) then on a reboot everything when belly up. Cameras won’t connect, z-wave enttities are all presumed dead and the mqtt doesn’t show anything.
  • Google Assistant
  • Harmony Hub
  • Cameras from my servers zoneminder
  • Z-Wave Aeotec Stick
  • Z-Wave Entry Door Light Switch
  • Z-Wave Back Door Light Switch
  • MQTT Light Switch Sonoff-Tasmota
Can you post your logs? Did you run the configuration check before restarting? You don’t need to do a full reboot after editing configuration.yaml by the way. You can just restart Home Assistant.
Also, please note the raspberry pi 2 will not provide a great experience with Home Assistant.
@Tediore I did, the config check was green. I wanted to get this minimum viable product in testing with the family before upgrading the hardware (understanding some slowness would be there).
Log:
2019-10-26 10:14:46 WARNING (MainThread) [homeassistant.loader] You are using a custom integration for hacs which has not been tested by Home Assistant. This component might cause stability problems, be sure to disable it if you do experience issues with Home Assistant.
2019-10-26 10:14:50 WARNING (Recorder) [homeassistant.components.recorder] Ended unfinished session (id=24 from 2019-10-26 13:43:57.286834)
2019-10-26 10:15:05 ERROR (MainThread) [homeassistant.config_entries] Error setting up entry Z-Wave for zwave
  File "/usr/local/lib/python3.7/site-packages/openzwave/option.py", line 78, in __init__
    raise ZWaveException(u"Can't find device %s : %s" % (device, traceback.format_exception(*sys.exc_info())))
openzwave.object.ZWaveException: "Zwave Generic Exception : Can't find device /dev/ttyACM1 : ['NoneType: None\\n']"
  File "/usr/src/homeassistant/homeassistant/config_entries.py", line 190, in async_setup
    hass, self
  File "/usr/src/homeassistant/homeassistant/components/zwave/__init__.py", line 366, in async_setup_entry
    config_path=config.get(CONF_CONFIG_PATH),
  File "/usr/local/lib/python3.7/site-packages/openzwave/option.py", line 81, in __init__
    raise ZWaveException(u"Error when retrieving device %s : %s" % (device, traceback.format_exception(*sys.exc_info())))
openzwave.object.ZWaveException: 'Zwave Generic Exception : Error when retrieving device /dev/ttyACM1 : [\'Traceback (most recent call last):\\n\', \'  File "/usr/local/lib/python3.7/site-packages/openzwave/option.py", line 78, in __init__\\n    raise ZWaveException(u"Can\\\'t find device %s : %s" % (device, traceback.format_exception(*sys.exc_info())))\\n\', \'openzwave.object.ZWaveException: "Zwave Generic Exception : Can\\\'t find device /dev/ttyACM1 : [\\\'NoneType: None\\\\\\\\n\\\']"\\n\']'
2019-10-26 10:15:05 WARNING (MainThread) [homeassistant.setup] Setup of google is taking over 10 seconds.
2019-10-26 10:15:05 ERROR (MainThread) [homeassistant.setup] Error during setup of component zoneminder
  File "/usr/local/lib/python3.7/site-packages/urllib3/connection.py", line 157, in _new_conn
    (self._dns_host, self.port), self.timeout, **extra_kw
  File "/usr/local/lib/python3.7/site-packages/urllib3/util/connection.py", line 84, in create_connection
    raise err
  File "/usr/local/lib/python3.7/site-packages/urllib3/util/connection.py", line 74, in create_connection
    sock.connect(sa)
OSError: [Errno 113] Host is unreachable
  File "/usr/local/lib/python3.7/site-packages/urllib3/connectionpool.py", line 672, in urlopen
    chunked=chunked,
  File "/usr/local/lib/python3.7/site-packages/urllib3/connectionpool.py", line 387, in _make_request
    conn.request(method, url, **httplib_request_kw)
  File "/usr/local/lib/python3.7/http/client.py", line 1244, in request
    self._send_request(method, url, body, headers, encode_chunked)
  File "/usr/local/lib/python3.7/http/client.py", line 1290, in _send_request
    self.endheaders(body, encode_chunked=encode_chunked)
  File "/usr/local/lib/python3.7/http/client.py", line 1239, in endheaders
    self._send_output(message_body, encode_chunked=encode_chunked)
  File "/usr/local/lib/python3.7/http/client.py", line 1026, in _send_output
    self.send(msg)
  File "/usr/local/lib/python3.7/http/client.py", line 966, in send
    self.connect()
  File "/usr/local/lib/python3.7/site-packages/urllib3/connection.py", line 184, in connect
    conn = self._new_conn()
  File "/usr/local/lib/python3.7/site-packages/urllib3/connection.py", line 169, in _new_conn
    self, "Failed to establish a new connection: %s" % e
urllib3.exceptions.NewConnectionError: <urllib3.connection.HTTPConnection object at 0x72b52390>: Failed to establish a new connection: [Errno 113] Host is unreachable
  File "/usr/local/lib/python3.7/site-packages/requests/adapters.py", line 449, in send
    timeout=timeout
  File "/usr/local/lib/python3.7/site-packages/urllib3/connectionpool.py", line 720, in urlopen
    method, url, error=e, _pool=self, _stacktrace=sys.exc_info()[2]
  File "/usr/local/lib/python3.7/site-packages/urllib3/util/retry.py", line 436, in increment
    raise MaxRetryError(_pool, url, error or ResponseError(cause))
urllib3.exceptions.MaxRetryError: HTTPConnectionPool(host='192.168.148.3', port=9080): Max retries exceeded with url: /zm/index.php (Caused by NewConnectionError('<urllib3.connection.HTTPConnection object at 0x72b52390>: Failed to establish a new connection: [Errno 113] Host is unreachable'))
  File "/usr/src/homeassistant/homeassistant/setup.py", line 171, in _async_setup_component
    component.setup, hass, processed_config  # type: ignore
  File "/usr/src/homeassistant/homeassistant/components/zoneminder/__init__.py", line 78, in setup
    success = zm_client.login() and success
  File "/usr/local/lib/python3.7/site-packages/zoneminder/zm.py", line 46, in login
    data=login_post, verify=self._verify_ssl)
  File "/usr/local/lib/python3.7/site-packages/requests/api.py", line 116, in post
    return request('post', url, data=data, json=json, **kwargs)
  File "/usr/local/lib/python3.7/site-packages/requests/api.py", line 60, in request
    return session.request(method=method, url=url, **kwargs)
  File "/usr/local/lib/python3.7/site-packages/requests/sessions.py", line 533, in request
    resp = self.send(prep, **send_kwargs)
  File "/usr/local/lib/python3.7/site-packages/requests/sessions.py", line 646, in send
    r = adapter.send(request, **kwargs)
  File "/usr/local/lib/python3.7/site-packages/requests/adapters.py", line 516, in send
    raise ConnectionError(e, request=request)
requests.exceptions.ConnectionError: HTTPConnectionPool(host='192.168.148.3', port=9080): Max retries exceeded with url: /zm/index.php (Caused by NewConnectionError('<urllib3.connection.HTTPConnection object at 0x72b52390>: Failed to establish a new connection: [Errno 113] Host is unreachable'))
2019-10-26 10:15:15 WARNING (MainThread) [homeassistant.setup] Setup of person is taking over 10 seconds.
2019-10-26 10:15:21 WARNING (MainThread) [homeassistant.components.remote] Setup of platform harmony is taking over 10 seconds.
2019-10-26 10:15:26 ERROR (MainThread) [homeassistant.setup] Unable to prepare setup for platform zoneminder.camera: Unable to set up component.
2019-10-26 19:32:39 ERROR (MainThread) [homeassistant.components.automation] Error while executing automation automation.watch_tv. Service not found for call_service at pos 1: Unable to find service input_boolean/turn_on
2019-10-26 19:32:59 ERROR (MainThread) [homeassistant.components.automation] Error while executing automation automation.watch_shield. Service not found for call_service at pos 1: Unable to find service input_boolean/turn_on
2019-10-27 03:35:33 ERROR (Thread-6) [pychromecast.socket_client] [Home group:42298] Error reading from socket.
2019-10-27 03:35:34 WARNING (Thread-6) [pychromecast.socket_client] [Home group:42298] Error communicating with socket, resetting connection
2019-10-27 03:36:03 WARNING (Thread-3) [pychromecast.socket_client] [Kitchen speaker:8009] Heartbeat timeout, resetting connection
2019-10-27 03:56:04 WARNING (Thread-5) [pychromecast.socket_client] [Master Bedroom speaker:8009] Heartbeat timeout, resetting connection
2019-10-27 09:00:29 ERROR (MainThread) [homeassistant.components.automation] Error while executing automation automation.watch_tv. Service not found for call_service at pos 1: Unable to find service input_boolean/turn_on
2019-10-28 04:07:12 ERROR (Thread-6) [pychromecast.socket_client] [Home group:42298] Error reading from socket.
2019-10-28 04:07:12 WARNING (Thread-6) [pychromecast.socket_client] [Home group:42298] Error communicating with socket, resetting connection
2019-10-28 04:07:37 WARNING (Thread-3) [pychromecast.socket_client] [Kitchen speaker:8009] Heartbeat timeout, resetting connection
2019-10-28 04:38:14 WARNING (Thread-5) [pychromecast.socket_client] [Master Bedroom speaker:8009] Heartbeat timeout, resetting connection
2019-10-28 06:00:48 ERROR (MainThread) [homeassistant.components.automation] Error while executing automation automation.watch_tv. Service not found for call_service at pos 1: Unable to find service input_boolean/turn_on
2019-10-28 10:34:54 ERROR (MainThread) [aioharmony.hubconnector] 192.168.148.197: Connection timed out for hub 14347800
2019-10-28 14:34:08 ERROR (MainThread) [homeassistant.components.automation] Error while executing automation automation.watch_tv. Service not found for call_service at pos 1: Unable to find service input_boolean/turn_on
2019-10-28 18:51:21 ERROR (MainThread) [homeassistant.components.automation] Error while executing automation automation.watch_tv. Service not found for call_service at pos 1: Unable to find service input_boolean/turn_on
2019-10-29 00:39:46 ERROR (MainThread) [aiohttp.server] Error handling request
  File "/usr/local/lib/python3.7/site-packages/aiohttp/web_protocol.py", line 275, in data_received
    messages, upgraded, tail = self._request_parser.feed_data(data)
  File "aiohttp\_http_parser.pyx", line 523, in aiohttp._http_parser.HttpParser.feed_data
aiohttp.http_exceptions.BadStatusLine: invalid HTTP method
2019-10-29 03:49:19 ERROR (Thread-6) [pychromecast.socket_client] [Home group:42298] Error reading from socket.
2019-10-29 03:49:19 WARNING (Thread-6) [pychromecast.socket_client] [Home group:42298] Error communicating with socket, resetting connection
2019-10-29 03:49:44 WARNING (Thread-3) [pychromecast.socket_client] [Kitchen speaker:8009] Heartbeat timeout, resetting connection
2019-10-29 03:56:06 WARNING (Thread-5) [pychromecast.socket_client] [Master Bedroom speaker:8009] Heartbeat timeout, resetting connection
2019-10-29 14:51:37 ERROR (MainThread) [homeassistant.components.automation] Error while executing automation automation.watch_tv. Service not found for call_service at pos 1: Unable to find service input_boolean/turn_on
2019-10-29 18:11:06 ERROR (MainThread) [homeassistant.components.automation] Error while executing automation automation.watch_tv. Service not found for call_service at pos 1: Unable to find service input_boolean/turn_on
2019-10-29 19:28:34 ERROR (MainThread) [homeassistant.components.automation] Error while executing automation automation.watch_shield. Service not found for call_service at pos 1: Unable to find service input_boolean/turn_on
2019-10-29 20:01:01 ERROR (MainThread) [homeassistant.components.automation] Error while executing automation automation.watch_tv. Service not found for call_service at pos 1: Unable to find service input_boolean/turn_on
2019-10-29 21:05:25 ERROR (MainThread) [homeassistant.components.automation] Error while executing automation automation.watch_shield. Service not found for call_service at pos 1: Unable to find service input_boolean/turn_on
2019-10-30 02:55:18 WARNING (Thread-5) [pychromecast.socket_client] [Master Bedroom speaker:8009] Heartbeat timeout, resetting connection
2019-10-30 04:05:24 ERROR (Thread-6) [pychromecast.socket_client] [Home group:42298] Error reading from socket.
2019-10-30 04:05:24 WARNING (Thread-6) [pychromecast.socket_client] [Home group:42298] Error communicating with socket, resetting connection
2019-10-30 04:05:49 WARNING (Thread-3) [pychromecast.socket_client] [Kitchen speaker:8009] Heartbeat timeout, resetting connection
2019-10-30 06:24:31 ERROR (MainThread) [homeassistant.components.automation] Error while executing automation automation.watch_tv. Service not found for call_service at pos 1: Unable to find service input_boolean/turn_on
I fixed the z-wave following this: ZWave stick USB port now configurable via GUI?
