I want to install octoprint server the same raspberry pi 4 where the home assistant os. is also running. Is it possible? I tried, but failed yet. I tried to install octoprint with portrainer, but it doesn’t work.
You have the wrong installation type to run stand alone servers alongside Home Assistant. If you do not want to change your installation method you should use an addon instead:
Try again. Github was having issues.
Also make sure you are using this URL:
https://github.com/fredrikbaberg/hassio-addons
You don’t appear to have the /hassio-addons
part.
Try again later. Looks like Github may still be having issues.
I tested it before posting my last message and it worked.
Just tried again and it did not work the first time.
Tried again 30 seconds later and it did work.
Also try refreshing your Supervisor Addon Store page with Ctrl+F5
CTRL+F5 works. Thank you.
Great. Good luck with it.
