I’m in the process of moving from a VM on a slow machine to a repurposed machine just for home assistant. Since it’s not a box I will be logging into all the time I would prefer to just run HAOS so that all the required updates are handled more or less automatically.
The box is currently running Ubuntu 20.04 with no issues, but because I won’t be having a need to log directly into this regularly (other than HA interfaces for home automation stuff itself), so I would like to avoid manually maintaining it.
I installed HA Core on it just fine and got it up and running as per a native Linux install and run it to realise Supervisor isn’t part of the deal.
I believe this would be a more-than-capable box, but I don’t really want to be running a VM on it since the CPU itself doesn’t support virtualisation. I realise that if I allocate pretty much all the system resources to the VM it would probably be fine, it will be installed as a headless unit.
Since the tech specs for the other boxes (ODROID, NUC, RasPi, Tinkerboard) aren’t specifically listed (I note there are many variations for most of those boards, eg ODROID: XU4, HC1, MC1, HC4, C4, N2+, etc, Raspi 1-4, various NUCs and so on), I thought I would just ask the question:
These are the specs of the box I’d like to put HAOS on:
CPU: Intel Celeron Broadwell SOC Processor, 3215U Quad core 2M Cache, 1.7 GHz,
with 8GB DDR3 1333MHz RAM and a 128GB
will this be suitable and which download should I use for it?
here is the actual machine: https://www.qotom.net/product/29.html
Any input appreciated.
