Can I ask for help installing the supervised Home Assistant I’m trying to install on a Debian 12 PC using Docker?
I followed several instructions and I stop at the same point in all of them. After running the code:
dpkg -i homeassistant-supervised.deb
I will stop at:
(Reading database ... 108736 files and directories currently installed.)
Preparing to unpack homeassistant-supervised.deb ...
[warn]
[warn] If you want more control over your own system, run
[warn] Home Assistant as a VM or run Home Assistant Core
[warn] via a Docker container.
[warn]
[error] Debian GNU/Linux bookworm/sid is not supported!
dpkg: error processing archive homeassistant-supervised.deb (--install):
new homeassistant-supervised package pre-installation script subprocess returned error exit status 1
[info] Undo divert on abort-install
No diversion 'diversion of /etc/NetworkManager/NetworkManager.conf to /etc/NetworkManager/NetworkManager.conf.real by homeassistant-supervised', none removed.
No diversion 'diversion of /etc/NetworkManager/system-connections/default to /etc/NetworkManager/system-connections/default.real by homeassistant-supervised', none removed.
No diversion 'diversion of /etc/docker/daemon.json to /etc/docker/daemon.json.real by homeassistant-supervised', none removed.
No diversion 'diversion of /etc/network/interfaces to /etc/network/interfaces.real by homeassistant-supervised', none removed.
[info] Resetting debconf selections
[info] Removal complete, due to the complexity of this installation method,
[info] you will need to manually remove the containers created by the supervisor
Errors were encountered while processing:
I’m trying to google it, but even trying to find the error, I can’t make any progress.
I don’t have a lot of experience with Linux OS, even less with docker, but I did a trial install on a Raspberry Pi with Raspbian without the slightest problem. The language barrier will also be a problem, because I don’t speak English very well and I’m trying to solve it with the help of translators.
Can anyone think of where I could be doing something wrong?
Is there a way to enforce install? I just installed a fresh Debian, and running into this issue now. I want to check cause I didn’t want the test version of Debian. I see now it was officially released 6 days ago.
What happened to the days when software is tested and updated before releases so they are ready for release day?
I’m onsite for only a few days. Is my only solution is format using Debian 11? Seems that way.
Why am I getting the same message now? Home Assistant seems to have supported Debian 12 for a long time.
I installed Debian 12, updated it, and am trying to install Home Assistant.
