I want to install xbmc-eventclients-xbmc-send, but in hassio there is no apt-get command how can I install…
you can’t.
Then again, HA does have the ability to control Kodi, so those packages shouldn’t be needed.
Aside from the Kodi query, apt-get is not available but I believe pip is (at least on the standard docker it is so I suspect on hass.io too) so you’ll need to find a package that’s available via pip
I need to run this command:
ssh kodi_username@kodi_ip_address 'xbmc-send -a "XBMC.RunPlugin(plugin://plugin.video.surveillanceroom?action=show_preview&camera_number=1)"'
I’m running this through json, it does the job … but not in the way that I wish. It takes me to the addon screen and performs the task. The first command only executes the task.
curl -i -X POST -H “Content-Type: application/json” -d ‘{“jsonrpc”:“2.0”,“method”:“Addons.ExecuteAddon”,“params”:{“wait”:false,“addonid”:“plugin.video.surveillanceroom”,“params”:{“action”:“show_preview”,“camera_number”:“1”,“id”:“1”}},“id”:2}’ http://192.168.1.20:8080/jsonrpc
Unable to execute XMBC.RunPlugin command by JSON
Hello, Sorry to everyone. I’ve solved the problem. Adding one more command.
Perhaps you should document your solution?
Actually ue did not need to install package.
I used one more command to control the kodi.
I said “document”, not “be vague”.
All right my buddy, I used the two commands through a .sh file and a shell_command.
curl -i -X POST -H "Content-Type: application/json" -d '{"jsonrpc":"2.0","method":"Addons.ExecuteAddon","params":{"wait":false,"addonid":"plugin.video.surveillanceroom","params":{"action":"show_preview","camera_number":"1","id":"1"}},"id":2}' http://192.168.1.163:8080/jsonrpc
curl -i -X POST -H "Content-Type: application/json" -d '{"jsonrpc": "2.0", "method": "GUI.SetFullscreen", "params": { "fullscreen": "toggle" }, "id": "1"}' http://192.168.1.163:8080/jsonrp
Thanks, it is always good to leave these details behind for others to learn.
Yes, don’t use hassio.
