I am trying to install Z-wave and I get this prompt
I tried putting my IP address into the localhost spot and got nothing. I then changed the port to my HA port and still got no result.
What am I supposed to do?
Did you install z-wave.js?
no am I supposed to?
yes, that is needed
The docs have all the answers you need:
If you aren’t using HAOS, or want to use the Z-Wave JS UI add-on instead of official one, go to the advanced installation instructions that is linked there.
I think my case is an edge case. I am running HA in docker, in a jail on truenas scale. I am having a problem getting my zwave 800 USB passed from the TN Server to the Jail so that HA can see it.
This problem will go away with the next release of truenas when docker replaces k3s
