Install success but can't log in
Hello Everyone,
I’m a newer here and these days I installed HA (version == 0.88.2 ) use python3.6 virtual env on my development board which arch == ARMv7l ,And I run HA use command “hass
–open-ui”
but i come across below problem:
And it display Error: invalid client id or redirect uri.Does any one come across this before,Please help me solve this.Thanks in advance.
Could i log in without authentication?I check forum and saw trusted work configuration in configuration.yaml but that function not support on version 0.88? How can I log in without authentication?
And I configure trusted net work in configuration.yaml and it display below error:
Why this antiquated version?
Even if you cannot go beyond python 3.6, it was only deprecated around version 0.100…
@koying Thanks for your reply.Because if I install the newest version and after installation i use “hass --open-ui” the start up will block and display below log and stop boot up and nothing print out.
Do you know what’s the reason?Thx!
