Install vscode (visual studio code) as a separate docker container
I am running my home-assistant (not HassIO) as a docker container and wanted to install vscode. Here is what I did.
  1. create local folders to hold vscode config data
mkdir /vscode
  1. install docker container
    docker run --name vscode --restart unless-stopped -p 8443:8443 -itd -v /vscode:/config -v /path_to_hass_config_folder:/config/workspace -e ‘TZ=Australia/Adelaide’ -e PASSWORD=xxx -e SUDO_PASSWORD=xxx linuxserver/code-server
  2. log into vscode web-ui on http://ip:8443. you should be able to see all your hass config files. At this point, we have a working code editor.
  3. However to make it similar to hassio extension, with all those autofill bells and whistles, we need to install a few extensions. I fetched the list from the official addon here.
emilast.LogFileHighlighter
ESPHome.esphome-vscode
keesschollaart.vscode-home-assistant
lukas-tr.materialdesignicons-intellisense
oderwat.indent-rainbow
redhat.vscode-yaml
usernamehw.errorlens
vscode-icons-team.vscode-icons
for some reason I am unable to search for them with in vscode web-ui. so I downloaded vsix files and install them manually. here is how I did it.
a) goto vscode market place and search for the above extensions, one at a time, and download them.
b) move those vsix files to vscode config folder
c) In the vscode web-ui, click on hamburger icon (top left) > view > extensions
d) in the extensions side bar click the 3 dots (’…’) and click “install from vsix”. under /config select and install the extensions, one by one.
  1. close the vscode web-ui (browser) and reopen it.
  2. In order to provide home-assistant access to vscode, in the settings, search for home assistant and provide url (http://ip:8123) and a long lived token.
  3. similarly you need to provide esphome url (http://ip:6052) as well.
hope this helps someone.
What does this provide that the normal VSCode extension doesn’t?
I think that’s the point. vscode is available as an add-on for hass.io, but add-ons aren’t available for a standard HA docker install. That’s what I understood anyway, but then I’ve not had much coffee today so…
I just installed VS Code in a docker container via docker-compose. I used this site as reference: (Thanks to whomever posted this)
My question is: Is there a way to load the Home Assistant Extension for VS Code with this type of configuration? I could figure it out.
UPDATE:
Found my own answer after a while … I didn’t realize that you could download these extensions and then import it via “Install from VSIX”
I don’t run hassio (just normal docker HA), and I have VSCode extension installed on VSCode. It connects to my HA and I get all the features.
So what I’m trying to figure out is what the add-on provides that the extension doesn’t. If it’s just a web browser version of VSCode, then cool. But if they are looking for just using normal VSCode with HA, the add-on/vscode server isn’t needed.
@flamingm0e
in your case, I think you are all set. I didn’t want to install and maintain vscode on each machine separately.
So what you’re saying is that it’s a web version of vscode? How hard is it to say that?
Thank you very much. Added this also in the side panel of my home assistant and works like a charm :slight_smile:
I’ve added the link to VS Code in the HA side panel but when I access it from there it doesn’t show the HA workspace like it does just going directly to the VS Code URL in the browser.
Is there a trick I’m missing to get it working?
I got the same problem. It resets to blank and you have to open recent workspace again.
@Clubke @finity
I fixed the instructions to correct this issue. please try again. thanks.
In my setup the port 8443 is used by Ubiquti Unifi.
@mcarty
you can map it any port. for example 8222 like below
-p 8222:8443
Works like a charm now :slight_smile:
Which container do you use for VSCode?
Using VSCode on Synology registry, I find tons of versions
Your help will be appreciated, thanks
Is is codercom/code-server?
no, its linuxserver/code-server
How do I get a HA side panel working ? Can you please provide your config for that. Thanks
Thanks for your guide.
I only have one problem:
I’m trying to install those VSIX files but every time I install one it only says:
“Please reload Visual Studio Code to complete installing the extension Python.”
And the actual extension doesn’t get installed.
I already tried restarting and refreshing everything but it just doesn’t work.
Any ideas?
Thanks a lot.
Hi hello
thanks
but i dont know why, cant connect do VS vis ip: 8443
i do have this in log :
standard_init_linux.go:211: exec user process caused "exec format error"
Thanks in advance
