Hi @BikeDude. Sorry for the delay. Are you sure you looked at the right place? All images seem to be public and I just tried to pull a couple of them without issue.
HI, I would like to ask you for help regarding the correct configuration of VSCODE and DB MARIA; basically, I use Home Assistant on docker compose installed on debian. the docker-compose,yaml file does not give me errors after configuring the VSCODE file; however I can’t use vscod. I think I’m confusing when indicating the volume. I’ll copy my compose file configuration to you. by the way I created a folder called code-server in .storage Could you help me understand what I’m doing wrong. Thank you
version: ‘3.9’
services:
home-assistant:
container_name: home-assistant
image: Package home-assistant · GitHub
volumes:
/home/deb/homeassistant:/config
/run/dbus:/run/dbus:ro
environment:
- TZ=Europe/Rome
network_mode: host
restart: always
Visual Studio code
vscode:
container_name: vscode
image: codercom/code-server:latest
restart: unless-stopped
environment:
PASSWORD: XXXXXXXX
volumes:
- /home/deb/homeassistant:/config
- /home/deb/homeassistant/.storage/share/code-server
ports:
- "7443:7443"
command: code-server --auth password --port 7443 --disable-telemetry /home/deb/homeassistant:/config
This is how I would set it up:
version: '3.7'
services:
db:
image: mariadb
environment:
MARIADB_ROOT_PASSWORD: [strong pw here]
MARIADB_DATABASE: homeassistant
MARIADB_USER: logger
MARIADB_PASSWORD: [strong pw here]
volumes:
- /srv/mariadb:/var/lib/mysql
ports:
- 3306:3306
homeassistant:
container_name: homeassistant
image: "ghcr.io/home-assistant/home-assistant:stable"
depends_on:
- db
volumes:
- /srv/homeassistant:/config
- /etc/localtime:/etc/localtime:ro
- /run/dbus:/run/dbus:ro
privileged: true
network_mode: host
code-server:
image: lscr.io/linuxserver/code-server:latest
container_name: code-server
environment:
- TZ=America/New_York
- PASSWORD=[strong pw here]
volumes:
- /srv/code-server:/config
- /srv/homeassistant:/ha ### <-- path to your ha installation
ports:
- 8443:8443
My working test setup for home assistant, mqtt and codeserver dockers so that codeserver has access to home assistant config folder. Just set passwords and all set to go.
Add this to docker-compose.yml:
version: '3'
services:
homeassistant:
image: homeassistant/home-assistant:latest
volumes:
- /opt/homeassistant:/config
ports:
- "8123:8123"
networks:
- homeassistant
codeserver:
user: 0:0
environment:
- PASSWORD=xxx
- SUDO_PASSWORD=yyy
volumes:
- /opt/codeserver:/root/.local/share/code-server
ports:
- "8080:8080"
networks:
- homeassistant
mosquitto:
image: eclipse-mosquitto
ports:
- "1883:1883"
- "9001:9001"
volumes:
- /opt/mosquitto/config:/mosquitto/config
- /opt/mosquitto/data:/mosquitto/data
- /opt/mosquitto/log:/mosquitto/log
networks:
- homeassistant
networks:
homeassistant:
driver: bridge
And give this command to download and start containers:
docker compose up -d
