Soooo , i made it work . I reinstalled Ubuntu , then VirtualBox , then Virtual box extended pack ( don`t know if it was necessary ) then I followed the tutorial from the link below , and it worked perfectly.
https://www.paulligocki.com/make-virtual-box-vm-autostart/
Make Virtual Box VM Autostart
Linux
Ubuntu 20.04
What you need to know
- VMNAME : Virtual Manchine Name that is registered with VirtualBox
- user : Account to run as
Edit /etc/default/virtualbox
sudo nano /etc/default/virtualbox
Add the following few lines into the file
#AutoStarting VMs
VBOXAUTOSTART_DB=/etc/vbox
VBOXAUTOSTART_CONFIG=/etc/vbox/autostart.cfg
Create /etc/systemd/system/VMNAME.service
sudo nano /etc/systemd/system/VMNAME.service
[Unit]
Description=vm1
After=network.target virtualbox.service
Before=runlevel2.target shutdown.target
[Service]
User=user
Group=vboxusers
Type=forking
Restart=no
TimeoutSec=5min
IgnoreSIGPIPE=no
KillMode=process
GuessMainPID=no
RemainAfterExit=yes
ExecStart=/usr/bin/VBoxManage startvm VMNAME --type headless
ExecStop=/usr/bin/VBoxManage controlvm VMNAME acpipowerbutton
[Install]
WantedBy=multi-user.target
Reload Daemon
sudo systemctl daemon-reload
Test
systemctl status VMNAME
Start
sudo systemctl start VMNAME
Stop
sudo systemctl stop VMNAME
Enable
sudo systemctl enable VMNAME
Disable
sudo systemctl disable VMNAME
