I’m experiencing a bootloop issue when installing Home Assistant OS (HAOS) on UTM SE. After I install HAOS, it boots and runs through the command line processes. However, shortly after, the display port becomes inactive, and the system restarts, entering a loop.
Here are some of the key command lines I’ve found:
• [ OK ]: Reached system reboot (this is the last message before it restarts)
• [ 29.8865]: Kernel command line says we are in first boot. (this appears just before the “Welcome to Home Assistant” message)
Has anyone encountered a similar issue or knows how to prevent the system from getting stuck in this reboot loop? I’ve tried adjusting a few settings in UTM SE but haven’t had any success yet.
Thanks!
