No, I have not stored it.
But I can copy the configuration.yaml
Alright. You should absolutely do that. If you donāt, the configuration is stored where the container runs and when you want to upgrade it will be gone.
I would start by creating a folder on your NAS where you store your container configuration. Then when you set up containers you point the container to that folder, for example
volumes:
- /share/container/zigbee2mqtt:/config
This means that all files that you store in your nas-folder /share/container/zigbee2mqtt (this is just an example) will be mapped to the containers config-folder.
After you get this working, you can recreate containers without losing the config.
But still no success.
I changed it to host. The container is running. I changed the port to 8099 in both (config und container).
What a messā¦
To confuse you even a bit more
You could try setting it up with docker-compose. Iām not sure how to do it in Synology, in QNAP I use the āapplicationā folder, then click create, Iām sure Synology has something similar.
Then you just paste this code and click create (after you have modified it to suit you):
version: '3.8'
services:
zigbee2mqtt:
container_name: zigbee2mqtt
image: koenkk/zigbee2mqtt
restart: unless-stopped
volumes:
- ./data:/app/data #MAKE THIS MATCH THE FOLDER WE TALKED ABOUT LAST POST
- /run/udev:/run/udev:ro
ports:
# Frontend port
- 8080:8080
environment:
- TZ=Europe/Berlin #SET YOUR TIMEZONE HERE
devices:
# Make sure this matched your adapter location
- /dev/serial/by-id/usb-Texas_Instruments_TI_CC2531_USB_CDC___0X00124B0018ED3DDF-if00:/dev/ttyACM0
Yes, on Synology there is something simular called āProjectā.
I installed everything using ssh, so i know the settings. But I will try tomorrow.
Thanks a lot for the help.
I tried it again with that kind of installation, but no success at all.
the container runs, but i can not reach the webinterface.
Itās really annoying:
The solution is so simple.
This entry in configuration.yaml does not work (source: Frontend | Zigbee2MQTT)
frontend: true
port: 8090
This entry works (source: [Experimental feature] Webbased frontend Ā· Issue #4266 Ā· Koenkk/zigbee2mqtt Ā· GitHub):
frontend:
port: 8090
Home Assistant is no fun like this. 3 hours wasted until I found this mistake.
I had showed an example
Itās not HomeAssistant that is at fault. Thatās basic YAML syntax. It can be confusing, but once you learn YAML, things get easier.
Yes, you are right. At that time I hadnāt yet understood that I also had to set the port in the system.
