Last week I was testing Home assistant to check if it would suite my needs and how to configure stuff.
I documented everything I did.
So yesterday I moved it to final to replace my old home automation system.
For this I decided to start with a clean slate so I don’t have any left overs from testing.
But I noticed a few difference.
I use HA 5.12 32bit on a Raspberry Pi 3A+. the same I used for testing.
During my testing HA would immediately find my scan and find my LG tv. But now it doesn’t.
I installed Tasmota, during my tests wifi statuses were visible but now not any more.
I’m sure I can enable all this again if I start searching, But why isn’t it added automatically like before?
Also I have 5 tasmota devices.
but 1 is listed under MQTT. the other 4 are listed under Tasmota
Basically, the Tasmota project is moving away from using Home Assistant’s MQTT Discovery process to their own style of device discovery (which is what Home Assistant’s Tasmota integration is for).
EDIT
I currently have only three Tasmotized devices, all use SetOption19 0 (which I believe is the default nowadays) and all three appear within the Tasmota integration.
Thank you
this SetOption19 was indeed the difference, now they are all listed under Tasmota.
do you also have an idea why the wifi status doesn’t appear automatically?
