Installation error 2
21-02-02 17:40:44 INFO (SyncWorker_4) [supervisor.docker.interface] Downloading docker image homeassistant/raspberrypi3-homeassistant with tag 2021.5.2.
21-02-02 17:40:45 ERROR (SyncWorker_4) [supervisor.docker.interface] Can’t install homeassistant/raspberrypi3-homeassistant:2021.5.2 → 500 Server Error for http+docker://localhost/v1.40/images/create?tag=2021.5.2&fromImage=homeassistant%2Fraspberrypi3-homeassistant: Internal Server Error (“Get “https://registry-1.docker.io/v2/”: x509: certificate has expired or is not yet valid: current time 2021-02-02T17:40:45Z is before 2021-04-25T00:00:00Z”).
21-02-02 17:40:45 WARNING (MainThread) [supervisor.homeassistant.core] Error on Home Assistant installation. Retry in 30sec
21-02-02 17:41:15 INFO (SyncWorker_3) [supervisor.docker.interface] Updating image homeassistant/raspberrypi3-homeassistant:landingpage to homeassistant/raspberrypi3-homeassistant:2021.5.2
21-02-02 17:41:15 INFO (SyncWorker_3) [supervisor.docker.interface] Downloading docker image homeassistant/raspberrypi3-homeassistant with tag 2021.5.2.
21-02-02 17:41:15 ERROR (SyncWorker_3) [supervisor.docker.interface] Can’t install homeassistant/raspberrypi3-homeassistant:2021.5.2 → 500 Server Error for http+docker://localhost/v1.40/images/create?tag=2021.5.2&fromImage=homeassistant%2Fraspberrypi3-homeassistant: Internal Server Error (“Get “https://registry-1.docker.io/v2/”: x509: certificate has expired or is not yet valid: current time 2021-02-02T17:41:15Z is before 2021-04-25T00:00:00Z”).
21-02-02 17:41:15 WARNING (MainThread) [supervisor.homeassistant.core] Error on Home Assistant installation. Retry in 30sec
I’ve completed all the steps.
The above error occurred when I tried to do it online. What should I do?
Welcome to HA! :slightly_smiling_face:
Is your system time properly set?
Can you tell me how to change the time?
Ahh, sorry, you’re installing Home Assistant OS?
No clue what goes wrong here.
I think it should set it if there’s an online connection.
There was a problem when I tried to download the image file and connect to the Internet according to the contents here.
I downloaded and ran the Raspberry Pi 3B 32bit image file.
Continuing the discussion from Installation error 2:
I also encountered this kind of problem (certificate has expired or is not yet valid), but I won’t change the system time. I can’t find a way to change the OS time after searching for a long time. Can anyone teach me?
(From a blunt mechanical translation, in fact my tone is very sincere)
I am also having the same problem. Any help is appreciated.
