Installation error first time set up
Hi there, I get stuck on a loop when setting up for the first time, this is where it get stuck, any ideas? I have restarted but with no luck, thanks
[supervisor.docker.interface] Can’t install ghcr.io/home-assistant/green-homeassistant:2023.12.3: 404 Client Error for http+docker://localhost/v1.43/images/ghcr.io/home-assistant/green-homeassistant:2023.12.3/json: Not Found (“No such image: Package green-homeassistant · GitHub”)
Any luck with this? I just got mine and upon installing it just shows error when downloading docker image. I haven’t seen anyone with an actual fix for this. To say the least its getting frustrating.
