Trying to install bare metal generic x86 and getting this error:
Not Found (“no such image: ghcr.io/home-assistant/generic-x86-64-homeassistant:2023.3.5: No such image: ghcr.io/home-assistant/generic-x86-64-homeassistant:2023.3.5”)
Does your networks works well?
Can you try to run nslookup ghcr.io
to check if the DNS is resolved?
gives me an unknown command error
I don’t know if dig or ping is present
But you can try curl -v ghcr.io/home-assistant/generic-x86-64-homeassistant:2023.3.5
Its got something to do with using an M2 NVME drive. I put the drive into an enclosure and it booted straight away.
You weren’t in the bash shell but in HA, I forgot to tell you to put those pronts in bash.
Good to know you solved it
Yes, it “solved” the issue, but I would like to install the NVME drive properly. It doesn’t look like I’m the only one having the issue either.
It’s maybe a driver or hardware issue, you can try to update your mother board firmware and check if there’s options to change how nvme drives are handled
The solution was here:
Did this an reflashed the drive and it took about 30 seconds to bring up the login screen.
Thanks for the suggestions/help though.
It’s exactly what I though but the name of the option depends on your mother board.
Those technologies need a driver on OS side to work.
As long as HA OS is optimised to work on low spec PCs I guess that no one cares about NVMe specific protocols
