Installation error
Hi guys,
I’m re-installing Hass.io after some problems on my RasPi3. I’ve a backup of snapshot on Dropbox so i want to copy snapshot and then recover it.
I’ve copied Hassio on a fresh SD and started it on Pi3. I’ve installed Samba addon but when I try to configure it I obtain this error message:
not a valid value for dictionary value @ data[‘options’]. Got {‘workgroup’: ‘WORKGROUP’, ‘username’: ‘hassio’, ‘password’: None, ‘interface’: ‘’, ‘allow_hosts’: [‘10.0.0.0/8’, ‘172.16.0.0/12’, ‘192.168.0.0/16’]}
I pressed SAVE without modifying standard configuration. I’m working on a Windows 10 system.
You have to modify the configuration. A username and password are required.
I’ve modified username and password, but i receive error message that can you read in the first post. I think that it is a problem with keybord codification.
did anybody solve the problem.
Why is there a plugin broken in the repository?
tryed 2 browsers - password changing from null is not excepted.
What to do=?
HI, Aniello, if you reinstalled Samba, you have to use the same user and password that you used on the previous installation
