Re-imaging my existing installation after a move to a new home, I decided to wipe and flash with the new image via Raspberry Pi Imager. All goes well with the flashing, then I startup and it seems that 2023.5.4 does not exist:
23-05-26 18:05:23 INFO (SyncWorker_0) [supervisor.docker.interface] Updating image ghcr.io/home-assistant/raspberrypi3-64-homeassistant:landingpage to ghcr.io/home-assistant/raspberrypi3-64-homeassistant:2023.5.4
23-05-26 18:05:23 INFO (MainThread) [supervisor.updater] Fetching update data from https://version.home-assistant.io/stable.json
23-05-26 18:05:23 INFO (SyncWorker_0) [supervisor.docker.interface] Downloading docker image ghcr.io/home-assistant/raspberrypi3-64-homeassistant with tag 2023.5.4.
23-05-26 18:05:23 INFO (MainThread) [supervisor.resolution.check] Starting system checks with state CoreState.RUNNING
23-05-26 18:05:23 INFO (MainThread) [supervisor.resolution.checks.base] Run check for IssueType.IPV4_CONNECTION_PROBLEM/ContextType.SYSTEM
23-05-26 18:05:23 INFO (MainThread) [supervisor.resolution.checks.base] Run check for IssueType.PWNED/ContextType.ADDON
23-05-26 18:05:23 INFO (MainThread) [supervisor.resolution.checks.base] Run check for IssueType.MULTIPLE_DATA_DISKS/ContextType.SYSTEM
23-05-26 18:05:23 INFO (MainThread) [supervisor.resolution.checks.base] Run check for IssueType.FREE_SPACE/ContextType.SYSTEM
23-05-26 18:05:23 INFO (MainThread) [supervisor.resolution.checks.base] Run check for IssueType.SECURITY/ContextType.CORE
23-05-26 18:05:23 INFO (MainThread) [supervisor.resolution.checks.base] Run check for IssueType.NO_CURRENT_BACKUP/ContextType.SYSTEM
23-05-26 18:05:23 INFO (MainThread) [supervisor.resolution.module] Create new suggestion SuggestionType.CREATE_FULL_BACKUP - ContextType.SYSTEM / None
23-05-26 18:05:23 INFO (MainThread) [supervisor.resolution.module] Create new issue IssueType.NO_CURRENT_BACKUP - ContextType.SYSTEM / None
23-05-26 18:05:23 INFO (MainThread) [supervisor.resolution.checks.base] Run check for IssueType.DNS_SERVER_FAILED/ContextType.DNS_SERVER
23-05-26 18:05:23 INFO (MainThread) [supervisor.resolution.checks.base] Run check for IssueType.TRUST/ContextType.SUPERVISOR
23-05-26 18:05:23 INFO (MainThread) [supervisor.resolution.checks.base] Run check for IssueType.DNS_SERVER_IPV6_ERROR/ContextType.DNS_SERVER
23-05-26 18:05:23 INFO (MainThread) [supervisor.resolution.check] System checks complete
23-05-26 18:05:23 INFO (MainThread) [supervisor.resolution.evaluate] Starting system evaluation with state CoreState.RUNNING
23-05-26 18:05:24 INFO (MainThread) [supervisor.resolution.evaluate] System evaluation complete
23-05-26 18:05:24 INFO (MainThread) [supervisor.resolution.fixup] Starting system autofix at state CoreState.RUNNING
23-05-26 18:05:24 INFO (MainThread) [supervisor.resolution.fixup] System autofix complete
23-05-26 18:05:24 INFO (MainThread) [supervisor.host.services] Updating service information
23-05-26 18:05:24 INFO (MainThread) [supervisor.host.network] Updating local network information
23-05-26 18:05:26 INFO (MainThread) [supervisor.host.sound] Updating PulseAudio information
23-05-26 18:05:26 INFO (MainThread) [supervisor.host.manager] Host information reload completed
23-05-26 18:06:57 ERROR (SyncWorker_0) [supervisor.docker.interface] Can't install ghcr.io/home-assistant/raspberrypi3-64-homeassistant:2023.5.4: 404 Client Error for http+docker://localhost/v1.42/images/ghcr.io/home-assistant/raspberrypi3-64-homeassistant:2023.5.4/json: Not Found ("No such image: ghcr.io/home-assistant/raspberrypi3-64-homeassistant:2023.5.4")
23-05-26 18:06:57 WARNING (MainThread) [supervisor.homeassistant.core] Error on Home Assistant installation. Retry in 30sec
23-05-26 18:07:27 INFO (SyncWorker_0) [supervisor.docker.interface] Updating image ghcr.io/home-assistant/raspberrypi3-64-homeassistant:landingpage to ghcr.io/home-assistant/raspberrypi3-64-homeassistant:2023.5.4
23-05-26 18:07:27 INFO (SyncWorker_0) [supervisor.docker.interface] Downloading docker image ghcr.io/home-assistant/raspberrypi3-64-homeassistant with tag 2023.5.4.
23-05-26 18:07:29 ERROR (SyncWorker_0) [supervisor.docker.interface] Can't install ghcr.io/home-assistant/raspberrypi3-64-homeassistant:2023.5.4: 404 Client Error for http+docker://localhost/v1.42/images/ghcr.io/home-assistant/raspberrypi3-64-homeassistant:2023.5.4/json: Not Found ("No such image: ghcr.io/home-assistant/raspberrypi3-64-homeassistant:2023.5.4")
23-05-26 18:07:29 WARNING (MainThread) [supervisor.homeassistant.core] Error on Home Assistant installation. Retry in 30sec
23-05-26 18:07:59 INFO (SyncWorker_2) [supervisor.docker.interface] Updating image ghcr.io/home-assistant/raspberrypi3-64-homeassistant:landingpage to ghcr.io/home-assistant/raspberrypi3-64-homeassistant:2023.5.4
23-05-26 18:07:59 INFO (SyncWorker_2) [supervisor.docker.interface] Downloading docker image ghcr.io/home-assistant/raspberrypi3-64-homeassistant with tag 2023.5.4.
23-05-26 18:08:00 ERROR (SyncWorker_2) [supervisor.docker.interface] Can't install ghcr.io/home-assistant/raspberrypi3-64-homeassistant:2023.5.4: 404 Client Error for http+docker://localhost/v1.42/images/ghcr.io/home-assistant/raspberrypi3-64-homeassistant:2023.5.4/json: Not Found ("No such image: ghcr.io/home-assistant/raspberrypi3-64-homeassistant:2023.5.4")
23-05-26 18:08:00 WARNING (MainThread) [supervisor.homeassistant.core] Error on Home Assistant installation. Retry in 30sec
23-05-26 18:08:30 INFO (SyncWorker_0) [supervisor.docker.interface] Updating image ghcr.io/home-assistant/raspberrypi3-64-homeassistant:landingpage to ghcr.io/home-assistant/raspberrypi3-64-homeassistant:2023.5.4
23-05-26 18:08:30 INFO (SyncWorker_0) [supervisor.docker.interface] Downloading docker image ghcr.io/home-assistant/raspberrypi3-64-homeassistant with tag 2023.5.4.
23-05-26 18:08:31 ERROR (SyncWorker_0) [supervisor.docker.interface] Can't install ghcr.io/home-assistant/raspberrypi3-64-homeassistant:2023.5.4: 404 Client Error for http+docker://localhost/v1.42/images/ghcr.io/home-assistant/raspberrypi3-64-homeassistant:2023.5.4/json: Not Found ("No such image: ghcr.io/home-assistant/raspberrypi3-64-homeassistant:2023.5.4")
23-05-26 18:08:31 WARNING (MainThread) [supervisor.homeassistant.core] Error on Home Assistant installation. Retry in 30sec
Any ideas?
