I’m trying to install esphome on a Sonoff 4CH Pro R3. I soldered a 5-pin header into the board, wired it up to a 3.3V USB-serial device (connecting TX-RX, RX-TX, GND-GND, 3.3V-3.3V), and connected to USB while holding down button 0 to put it in programming mode. So far so good, everything seems to work.
Then I tried to flash it with esphome run mydev.yaml
, where the YAML file contains something like this:
esphome:
esp8266:
board: esp8285
# Enable logging
logger:
# Enable Home Assistant API
api:
password: "secret"
ota:
password: "secret"
wifi:
ssid: "mySSID"
password: "WiFi password"
ap:
ssid: "myespFallback"
password: "APpassword"
captive_portal:
At first, it looks like it’s working, but then the installation process hangs with:
Uploading stub...
Running stub...
Stub running...
Changing baud rate to 460800
Changed.
Configuring flash size...
Auto-detected Flash size: 1MB
Flash will be erased from 0x00000000 to 0x00062fff...
Compressed 402896 bytes to 284168...
Wrote 402896 bytes (284168 compressed) at 0x00000000 in 6.5 seconds (effective 495.6 kbit/s)...
Hash of data verified.
Leaving...
Hard resetting via RTS pin...
INFO Successfully uploaded program.
INFO Starting log output from /dev/ttyUSB1 with baud rate 115200
Of course, I have no RTS pin, so I don’t know how it would expect to hard reset the device like this. If I try to reset it by removing the 3.3V power pin temporarily, then esphome
exits immediately with an error. Can someone tell me how to work around this issue? I’m sure it’s something silly, but I’m new to esphome so haven’t gotten it working yet. Thanks.
