Hey,
The installation fails on a Raspberry 3B with the following error, using a 32GB SD card. Any hint would be greatly appreciated, thanks!
s6-rc: info: service s6rc-oneshot-runner: starting
s6-rc: info: service s6rc-oneshot-runner successfully started
s6-rc: info: service fix-attrs: starting
s6-rc: info: service fix-attrs successfully started
s6-rc: info: service legacy-cont-init: starting
cont-init: info: running /etc/cont-init.d/udev.sh
[22:04:20] INFO: Using udev information from host
cont-init: info: /etc/cont-init.d/udev.sh exited 0
s6-rc: info: service legacy-cont-init successfully started
s6-rc: info: service legacy-services: starting
services-up: info: copying legacy longrun supervisor (no readiness notification)
services-up: info: copying legacy longrun watchdog (no readiness notification)
s6-rc: info: service legacy-services successfully started
[22:04:20] INFO: Starting local supervisor watchdog...
24-04-19 22:04:29 INFO (MainThread) [__main__] Initializing Supervisor setup
24-04-19 22:04:29 INFO (MainThread) [supervisor.docker.network] Can't find Supervisor network, creating a new network
24-04-19 22:04:30 INFO (MainThread) [supervisor.bootstrap] Setting up coresys for machine: raspberrypi3-64
24-04-19 22:04:30 INFO (MainThread) [supervisor.docker.supervisor] Attaching to Supervisor ghcr.io/home-assistant/aarch64-hassio-supervisor with version 2024.03.0
24-04-19 22:04:30 INFO (MainThread) [supervisor.docker.supervisor] Connecting Supervisor to hassio-network
24-04-19 22:04:30 INFO (MainThread) [supervisor.resolution.evaluate] Starting system evaluation with state initialize
24-04-19 22:04:30 INFO (MainThread) [supervisor.resolution.evaluate] System evaluation complete
24-04-19 22:04:30 INFO (MainThread) [__main__] Setting up Supervisor
24-04-19 22:04:31 INFO (MainThread) [supervisor.api] Starting API on 172.30.32.2
24-04-19 22:04:31 INFO (MainThread) [supervisor.hardware.monitor] Started Supervisor hardware monitor
24-04-19 22:04:31 INFO (MainThread) [supervisor.dbus.manager] Connected to system D-Bus.
24-04-19 22:04:31 INFO (MainThread) [supervisor.dbus.agent] Load dbus interface io.hass.os
24-04-19 22:04:31 INFO (MainThread) [supervisor.dbus.hostname] Load dbus interface org.freedesktop.hostname1
24-04-19 22:04:31 INFO (MainThread) [supervisor.dbus.logind] Load dbus interface org.freedesktop.login1
24-04-19 22:04:31 INFO (MainThread) [supervisor.dbus.network] Load dbus interface org.freedesktop.NetworkManager
24-04-19 22:04:31 INFO (MainThread) [supervisor.dbus.rauc] Load dbus interface de.pengutronix.rauc
24-04-19 22:04:31 INFO (MainThread) [supervisor.dbus.resolved] Load dbus interface org.freedesktop.resolve1
24-04-19 22:04:31 INFO (MainThread) [supervisor.dbus.systemd] Load dbus interface org.freedesktop.systemd1
24-04-19 22:04:31 INFO (MainThread) [supervisor.dbus.timedate] Load dbus interface org.freedesktop.timedate1
24-04-19 22:04:32 INFO (MainThread) [supervisor.host.services] Updating service information
24-04-19 22:04:32 INFO (MainThread) [supervisor.host.sound] Updating PulseAudio information
24-04-19 22:04:32 WARNING (SyncWorker_0) [supervisor.host.sound] Can't update PulseAudio data: Failed to connect to pulseaudio server
24-04-19 22:04:32 INFO (MainThread) [supervisor.host.network] Updating local network information
24-04-19 22:04:33 INFO (MainThread) [supervisor.host.apparmor] Loading AppArmor Profiles: {'hassio-supervisor'}
24-04-20 00:04:33 INFO (MainThread) [supervisor.docker.monitor] Started docker events monitor
24-04-20 00:04:33 INFO (MainThread) [supervisor.updater] Fetching update data from https://version.home-assistant.io/stable.json
24-04-20 00:04:33 INFO (MainThread) [supervisor.docker.interface] Found ghcr.io/home-assistant/aarch64-hassio-cli versions: [<AwesomeVersion CalVer '2024.03.1'>]
24-04-20 00:04:33 INFO (MainThread) [supervisor.docker.interface] Attaching to ghcr.io/home-assistant/aarch64-hassio-cli with version 2024.03.1
24-04-20 00:04:33 INFO (MainThread) [supervisor.plugins.cli] Starting CLI plugin
24-04-20 00:04:34 INFO (MainThread) [supervisor.docker.cli] Starting CLI ghcr.io/home-assistant/aarch64-hassio-cli with version 2024.03.1 - 172.30.32.5
24-04-20 00:04:34 INFO (MainThread) [supervisor.docker.interface] Found ghcr.io/home-assistant/aarch64-hassio-dns versions: [<AwesomeVersion CalVer '2024.03.0'>]
24-04-20 00:04:34 INFO (MainThread) [supervisor.docker.interface] Attaching to ghcr.io/home-assistant/aarch64-hassio-dns with version 2024.03.0
24-04-20 00:04:35 INFO (MainThread) [supervisor.plugins.dns] Starting CoreDNS plugin
24-04-20 00:04:37 INFO (MainThread) [supervisor.docker.dns] Starting DNS ghcr.io/home-assistant/aarch64-hassio-dns with version 2024.03.0 - 172.30.32.3
24-04-20 00:04:37 INFO (MainThread) [supervisor.plugins.dns] Updated /etc/resolv.conf
24-04-20 00:04:37 INFO (MainThread) [supervisor.docker.interface] Found ghcr.io/home-assistant/aarch64-hassio-audio versions: [<AwesomeVersion CalVer '2023.12.0'>]
24-04-20 00:04:37 INFO (MainThread) [supervisor.docker.interface] Attaching to ghcr.io/home-assistant/aarch64-hassio-audio with version 2023.12.0
24-04-20 00:04:37 INFO (MainThread) [supervisor.plugins.audio] Starting Audio plugin
24-04-20 00:04:38 INFO (MainThread) [supervisor.docker.audio] Starting Audio ghcr.io/home-assistant/aarch64-hassio-audio with version 2023.12.0 - 172.30.32.4
24-04-20 00:04:39 INFO (MainThread) [supervisor.docker.interface] Found ghcr.io/home-assistant/aarch64-hassio-observer versions: [<AwesomeVersion CalVer '2023.06.0'>]
24-04-20 00:04:39 INFO (MainThread) [supervisor.docker.interface] Attaching to ghcr.io/home-assistant/aarch64-hassio-observer with version 2023.06.0
24-04-20 00:04:39 INFO (MainThread) [supervisor.plugins.observer] Starting observer plugin
24-04-20 00:04:40 INFO (MainThread) [supervisor.docker.observer] Starting Observer ghcr.io/home-assistant/aarch64-hassio-observer with version 2023.06.0 - 172.30.32.6
24-04-20 00:04:41 INFO (MainThread) [supervisor.docker.interface] Found ghcr.io/home-assistant/aarch64-hassio-multicast versions: [<AwesomeVersion CalVer '2024.03.0'>]
24-04-20 00:04:41 INFO (MainThread) [supervisor.docker.interface] Attaching to ghcr.io/home-assistant/aarch64-hassio-multicast with version 2024.03.0
24-04-20 00:04:41 INFO (MainThread) [supervisor.plugins.multicast] Starting Multicast plugin
24-04-20 00:04:42 INFO (MainThread) [supervisor.docker.multicast] Starting Multicast ghcr.io/home-assistant/aarch64-hassio-multicast with version 2024.03.0 - Host
24-04-20 00:04:42 INFO (MainThread) [supervisor.homeassistant.secrets] Loaded 0 Home Assistant secrets
24-04-20 00:04:42 INFO (MainThread) [supervisor.docker.interface] No version found for ghcr.io/home-assistant/raspberrypi3-64-homeassistant
24-04-20 00:04:42 INFO (MainThread) [supervisor.homeassistant.core] No Home Assistant Docker image ghcr.io/home-assistant/raspberrypi3-64-homeassistant found.
24-04-20 00:04:42 INFO (MainThread) [supervisor.docker.interface] Attaching to ghcr.io/home-assistant/raspberrypi3-64-homeassistant with version landingpage
24-04-20 00:04:42 INFO (MainThread) [supervisor.homeassistant.core] Using preinstalled landingpage
24-04-20 00:04:42 INFO (MainThread) [supervisor.homeassistant.core] Starting HomeAssistant landingpage
24-04-20 00:04:42 INFO (MainThread) [supervisor.homeassistant.module] Update pulse/client.config: /data/tmp/homeassistant_pulse
24-04-20 00:04:44 INFO (MainThread) [supervisor.docker.homeassistant] Starting Home Assistant ghcr.io/home-assistant/raspberrypi3-64-homeassistant with version landingpage
24-04-20 00:04:44 INFO (MainThread) [supervisor.os.manager] Detect Home Assistant Operating System 12.1 / BootSlot A
24-04-20 00:04:44 INFO (MainThread) [supervisor.store.git] Cloning add-on https://github.com/esphome/home-assistant-addon repository
24-04-20 00:04:44 INFO (MainThread) [supervisor.store.git] Cloning add-on https://github.com/home-assistant/addons repository
24-04-20 00:04:44 INFO (MainThread) [supervisor.store.git] Cloning add-on https://github.com/hassio-addons/repository repository
24-04-20 00:04:47 INFO (MainThread) [supervisor.store] Loading add-ons from store: 77 all - 77 new - 0 remove
24-04-20 00:04:47 INFO (MainThread) [supervisor.addons.manager] Found 0 installed add-ons
24-04-20 00:04:47 INFO (MainThread) [supervisor.backups.manager] Found 0 backup files
24-04-20 00:04:47 INFO (MainThread) [supervisor.discovery] Loaded 0 messages
24-04-20 00:04:47 INFO (MainThread) [supervisor.ingress] Loaded 0 ingress sessions
24-04-20 00:04:47 INFO (MainThread) [supervisor.resolution.check] Starting system checks with state setup
24-04-20 00:04:47 INFO (MainThread) [supervisor.resolution.check] System checks complete
24-04-20 00:04:47 INFO (MainThread) [supervisor.resolution.evaluate] Starting system evaluation with state setup
24-04-20 00:04:47 INFO (MainThread) [supervisor.resolution.evaluate] System evaluation complete
24-04-20 00:04:47 INFO (MainThread) [supervisor.jobs] 'ResolutionFixup.run_autofix' blocked from execution, system is not running - setup
24-04-20 00:04:47 INFO (MainThread) [__main__] Running Supervisor
24-04-20 00:04:47 INFO (MainThread) [supervisor.os.manager] Rauc: A - marked slot kernel.0 as good
24-04-20 00:04:47 INFO (MainThread) [supervisor.supervisor] Fetching AppArmor profile https://version.home-assistant.io/apparmor_stable.txt
24-04-20 00:04:48 INFO (MainThread) [supervisor.host.apparmor] Adding/updating AppArmor profile: hassio-supervisor
24-04-20 00:04:48 INFO (MainThread) [supervisor.supervisor] Update Supervisor to version 2024.04.0
24-04-20 00:04:48 INFO (MainThread) [supervisor.docker.interface] Downloading docker image ghcr.io/home-assistant/aarch64-hassio-supervisor with tag 2024.04.0.
24-04-20 00:05:04 INFO (MainThread) [supervisor.hardware.monitor] Detecting remove hardware /dev/bus/usb/001/003 - None
24-04-20 00:05:04 INFO (MainThread) [supervisor.hardware.monitor] Detecting remove hardware /dev/ttyACM0 - /dev/serial/by-id/usb-ITEAD_SONOFF_Zigbee_3.0_USB_Dongle_Plus_V2_20231219145042-if00
24-04-20 00:05:04 INFO (MainThread) [supervisor.hardware.monitor] Detecting remove hardware /dev/bus/usb/001/004 - None
24-04-20 00:05:04 INFO (MainThread) [supervisor.hardware.monitor] Detecting remove hardware /dev/bus/usb/001/002 - None
24-04-20 00:05:06 INFO (MainThread) [supervisor.hardware.monitor] Detecting add hardware /dev/bus/usb/001/005 - None
24-04-20 00:05:07 INFO (MainThread) [supervisor.hardware.monitor] Detecting add hardware /dev/bus/usb/001/006 - None
24-04-20 00:05:07 INFO (MainThread) [supervisor.hardware.monitor] Detecting add hardware /dev/bus/usb/001/007 - None
24-04-20 00:05:07 INFO (MainThread) [supervisor.hardware.monitor] Detecting add hardware /dev/ttyACM0 - /dev/serial/by-id/usb-ITEAD_SONOFF_Zigbee_3.0_USB_Dongle_Plus_V2_20231219145042-if00
24-04-20 00:05:07 ERROR (MainThread) [asyncio] Task exception was never retrieved
future: <Task finished name='Task-419' coro=<HomeAssistant._hardware_events() done, defined at /usr/src/supervisor/supervisor/homeassistant/module.py:311> exception=AwesomeVersionCompareException("Can't compare <unknown landingpage> and <CalVer 2021.9.0>")>
File "/usr/src/supervisor/supervisor/homeassistant/module.py", line 316, in _hardware_events
or self.version < "2021.9.0"
File "/usr/local/lib/python3.12/site-packages/awesomeversion/awesomeversion.py", line 172, in __lt__
raise AwesomeVersionCompareException(
awesomeversion.exceptions.AwesomeVersionCompareException: Can't compare <unknown landingpage> and <CalVer 2021.9.0>
24-04-20 00:05:23 INFO (MainThread) [supervisor.hardware.monitor] Detecting remove hardware /dev/bus/usb/001/006 - None
24-04-20 00:05:23 INFO (MainThread) [supervisor.hardware.monitor] Detecting remove hardware /dev/ttyACM0 - /dev/serial/by-id/usb-ITEAD_SONOFF_Zigbee_3.0_USB_Dongle_Plus_V2_20231219145042-if00
24-04-20 00:05:23 INFO (MainThread) [supervisor.hardware.monitor] Detecting remove hardware /dev/bus/usb/001/007 - None
24-04-20 00:05:23 INFO (MainThread) [supervisor.hardware.monitor] Detecting remove hardware /dev/bus/usb/001/005 - None
24-04-20 00:05:25 INFO (MainThread) [supervisor.hardware.monitor] Detecting add hardware /dev/bus/usb/001/008 - None
24-04-20 00:05:25 INFO (MainThread) [supervisor.hardware.monitor] Detecting add hardware /dev/bus/usb/001/009 - None
24-04-20 00:05:26 INFO (MainThread) [supervisor.hardware.monitor] Detecting add hardware /dev/bus/usb/001/010 - None
24-04-20 00:05:26 INFO (MainThread) [supervisor.hardware.monitor] Detecting add hardware /dev/ttyACM0 - /dev/serial/by-id/usb-ITEAD_SONOFF_Zigbee_3.0_USB_Dongle_Plus_V2_20231219145042-if00
24-04-20 00:05:26 ERROR (MainThread) [asyncio] Task exception was never retrieved
future: <Task finished name='Task-506' coro=<HomeAssistant._hardware_events() done, defined at /usr/src/supervisor/supervisor/homeassistant/module.py:311> exception=AwesomeVersionCompareException("Can't compare <unknown landingpage> and <CalVer 2021.9.0>")>
