I just tried to install Hass on my brand new RPi3.
I did flash the (brand new) 32 GB SD card with Etcher, everything worked fine.
I then plugged it into my RPi3 and could see (from the hassio.portal portal) the splash screen saying that Hass.io was installing and that it could take up to 20 minutes.
After a hour : still the splashscreen.
I have to say that the Rpi is connected to the router directly on ethernet and that I have not changed any config file or anything on the SD card.
I try to access the platform through the IP address, but I get an navigator error : it can’t actually find anything at the specified IP address. The splash screen itself is still here, but at the hassio.local:8123.
I switched it off and let it run all night but I still get the same : everything looks stuck.
Any idea ?
Thanks a lot.
