Installation HA core on docker debian fails at startup
Hi everyone,
I just tried to install HA core on docker debian as non-root with the following command line:
docker run -d --name="home-assistant" -e "TZ=Europe/Rome" -v ~/homeassistant:/config -v /run/dbus:/run/dbus:ro --net=host --restart always ghcr.io/home-assistant/home-assistant:stable
but it fails at startup, here’s the log:
2024-10-31 16:52:29 s6-rc: info: service legacy-services: stopping
2024-10-31 16:52:29 s6-rc: info: service legacy-services successfully stopped
2024-10-31 16:52:29 s6-rc: info: service legacy-cont-init: stopping
2024-10-31 16:52:29 s6-rc: info: service legacy-cont-init successfully stopped
2024-10-31 16:52:29 s6-rc: info: service fix-attrs: stopping
2024-10-31 16:52:29 s6-rc: info: service fix-attrs successfully stopped
2024-10-31 16:52:29 s6-rc: info: service s6rc-oneshot-runner: stopping
2024-10-31 16:52:29 s6-rc: info: service s6rc-oneshot-runner successfully stopped
2024-10-31 16:52:32 s6-rc: info: service s6rc-oneshot-runner: starting
2024-10-31 16:52:32 s6-rc: info: service s6rc-oneshot-runner successfully started
2024-10-31 16:52:32 s6-rc: info: service fix-attrs: starting
2024-10-31 16:52:32 s6-rc: info: service fix-attrs successfully started
2024-10-31 16:52:32 s6-rc: info: service legacy-cont-init: starting
2024-10-31 16:52:32 s6-rc: info: service legacy-cont-init successfully started
2024-10-31 16:52:32 s6-rc: info: service legacy-services: starting
2024-10-31 16:52:32 services-up: info: copying legacy longrun home-assistant (no readiness notification)
2024-10-31 16:52:32 s6-rc: info: service legacy-services successfully started
2024-10-31 16:52:34 Traceback (most recent call last):
2024-10-31 16:52:34   File "<frozen runpy>", line 198, in _run_module_as_main
2024-10-31 16:52:34   File "<frozen runpy>", line 88, in _run_code
2024-10-31 16:52:34   File "/usr/src/homeassistant/homeassistant/__main__.py", line 223, in <module>
2024-10-31 16:52:34     sys.exit(main())
2024-10-31 16:52:34              ^^^^^^
2024-10-31 16:52:34   File "/usr/src/homeassistant/homeassistant/__main__.py", line 207, in main
2024-10-31 16:52:34     with open(fault_file_name, mode="a", encoding="utf8") as fault_file:
2024-10-31 16:52:34          ^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^
2024-10-31 16:52:34 PermissionError: [Errno 13] Permission denied: '/config/home-assistant.log.fault'
2024-10-31 16:52:34 [15:52:34] INFO: Home Assistant Core finish process exit code 1
2024-10-31 16:52:34 [15:52:34] INFO: Home Assistant Core service shutdown
How can I solve this?
Thank you
Blockquote
You are mounting the volume as read only, so Home Assiststant has no permissions to write to it. Remove that and try again.
the dbus is in ro it is ok.
Did you give to the user executing the command the or the group of the user the right to read/write and execute?
As you docker is spinning up, I suppose, you have the non root user in a docker group but then I believe you need to specify the PUID and PUIG in order to make HA work fine.
See this: Improving Docker security - non-root configuration - #8 by thi_baut
If it is a security concern, you need to pay attention to host network as well.
hope it helps.
Use macvlan
It’ll avoid the mdns issues you will eventually learn about
