I just tried to install Homeassistant on my mini PC using a USB stick. After the installation, the message comes up with an emergency… After a reboot, I found that the old operating system is still on the disk. Who can help me?
thank you
thank you
Welcome, but this forum is english-only…
I assume you are trying to install Home Assistant OS.
As a next step, we need to write the Operating System image to the target boot media (Your “boot media” is the disk, SSD, or eMMC that your x86-64 hardware will boot from when it is running Home Assistant). Depending on your system this can be a S-ATA hard disk, S-ATA SSD, a M.2 SSD or even a eMMC. Home Assistant Operating System has no integrated installer. You need to use your Desktop computer (e.g. by using a USB to S-ATA adapter) or boot a live operating system on your target system to install Home Assistant Operating System, by writing the disk image directly onto the boot media for your x86 system.
