Was working with a previous install of Hassbian - re-imaged and reset Z Wave Stick. Now I get a "openzwave.object.ZWaveException: 'Zwave Generic Exception : Error when retrieving device /dev/ttyACM0 "
Have tried a soft reset of network via Z-wave Network Management also
Reboot Hasbian and will appear again - re-start service and Error config will show in dashboard
Error from HA Log:
2017-06-02 08:27:47.998 Always, OpenZwave Version 1.4.2508 Starting Up
2017-06-02 08:27:50.446 Info, Setting Up Provided Network Key for Secure Communications
2017-06-02 08:27:50.446 Warning, Failed - Network Key Not Set
2017-06-02 08:27:50.446 Info, mgr, Added driver for controller /dev/ttyACM0
2017-06-02 08:27:50.446 Info, Opening controller /dev/ttyACM0
2017-06-02 08:27:50.446 Info, Trying to open serial port /dev/ttyACM0 (attempt 1)
If you need access to the root user, use a “sudo su” command. That will bypass any password requirements. Only use root when absolutely necessary. 1 fat finger command can screw up an entire install.
OK, so it sounds like /dev/ttyACM0 is the correct device. Any errors shown in /var/log/messages? Unfortunately the HA log isn’t very verbose. Sometimes you can get more verbose messages by using
Thanks for your patience - so sudo su command came back with this now 0 and 1"[ 3.174568] cdc_acm 1-1.4:1.0: ttyACM0: USB ACM device
[ 200.791647] cdc_acm 1-1.4:1.0: ttyACM1: USB ACM device" two
From what I can recall there is no OZWCP installed as the post install scripts recommended the Open Z-Wave Pip version instead of the other.
sudo journalctl -fu home-assistant - this log is empty?
did a search of the messages file and nothing obvious there from what I can see
"Jun 1 23:06:45 hassbian kernel: [ 2.335680] usb 1-1.5: new full-speed USB device number 4 using dwc_otg
Jun 1 23:06:45 hassbian kernel: [ 2.468927] usb 1-1.5: New USB device found, idVendor=0658, idProduct=0200
Jun 1 23:06:45 hassbian kernel: [ 2.471249] usb 1-1.5: New USB device strings: Mfr=0, Product=0, SerialNumber=0
Jun 1 23:07:46 hassbian kernel: [ 58.529435] usb 1-1.5: USB disconnect, device number 4
Jun 1 23:08:22 hassbian kernel: [ 95.175631] usb 1-1.5: new full-speed USB device number 5 using dwc_otg
Jun 1 23:08:23 hassbian kernel: [ 95.308912] usb 1-1.5: New USB device found, idVendor=0658, idProduct=0200
Jun 1 23:08:23 hassbian kernel: [ 95.308920] usb 1-1.5: New USB device strings: Mfr=0, Product=0, SerialNumber=0
Have attached the full HA log as an attachment - thanks so much for helping BTW
I don’t know if it has changed, but the Hasspian image did not work for me at all as of a month ago. I installed the stock Raspberry OS and used the AIOI.
