Hi
I try to install a palette in my Node-Red add-on in HAOS but it fails. It looks like it’s unable to install python dependency. Is there a way to go around ? or it’s a dead-end with Node-Red on HAOS ?
Palette I try to install: node-red-contrib-socketcan (node) - Node-RED
Logs of install in node-red of the palette:
2025-01-08T15:19:56.497Z Installer : node-red-contrib-socketcan 1.2.14
2025-01-08T15:19:56.533Z npm install --no-audit --no-update-notifier --no-fund --save --save-prefix=~ --omit=dev --engine-strict [email protected]
2025-01-08T15:20:04.717Z [err] npm warn deprecated [email protected]: This module is not supported, and leaks memory. Do not use it. Check out lru-cache if you want a good and tested way to coalesce async requests by a key value, which is much more comprehensive and powerful.
2025-01-08T15:20:04.729Z [err] npm warn deprecated [email protected]: This package is no longer supported.
2025-01-08T15:20:04.758Z [err] npm warn deprecated [email protected]: Rimraf versions prior to v4 are no longer supported
2025-01-08T15:20:04.777Z [err] npm warn deprecated [email protected]: This package is no longer supported.
2025-01-08T15:20:04.784Z [err] npm warn deprecated [email protected]: Glob versions prior to v9 are no longer supported
2025-01-08T15:20:04.843Z [err] npm warn deprecated [email protected]: This package is no longer supported.
2025-01-08T15:20:05.330Z [err] npm warn cleanup Failed to remove some directories [
2025-01-08T15:20:05.330Z [err] npm warn cleanup [
2025-01-08T15:20:05.330Z [err] npm warn cleanup '/config/node_modules/bcrypt',
2025-01-08T15:20:05.330Z [err] npm warn cleanup [Error: ENOTEMPTY: directory not empty, rmdir '/config/node_modules/bcrypt'] {
2025-01-08T15:20:05.330Z [err] npm warn cleanup errno: -39,
2025-01-08T15:20:05.330Z [err] npm warn cleanup code: 'ENOTEMPTY',
2025-01-08T15:20:05.330Z [err] npm warn cleanup syscall: 'rmdir',
2025-01-08T15:20:05.330Z [err] npm warn cleanup path: '/config/node_modules/bcrypt'
2025-01-08T15:20:05.330Z [err] npm warn cleanup }
2025-01-08T15:20:05.330Z [err] npm warn cleanup ],
2025-01-08T15:20:05.334Z [err] npm error code 1
2025-01-08T15:20:05.334Z [err] npm error path /config/node_modules/socketcan
2025-01-08T15:20:05.334Z [err] npm error command failed
2025-01-08T15:20:05.334Z [err] npm error command sh -c node-gyp rebuild
2025-01-08T15:20:05.334Z [err] npm error gyp info it worked if it ends with ok
2025-01-08T15:20:05.334Z [err] npm error gyp info using [email protected]
2025-01-08T15:20:05.334Z [err] npm error gyp info using [email protected] | linux | x64
2025-01-08T15:20:05.334Z [err] npm error gyp ERR! find Python
2025-01-08T15:20:05.334Z [err] npm error gyp ERR! find Python checking Python explicitly set from command line or npm configuration
2025-01-08T15:20:05.334Z [err] npm error gyp ERR! find Python - "--python=" or "npm config get python" is "/usr/bin/python3"
2025-01-08T15:20:05.334Z [err] npm error gyp ERR! find Python - executable path is ""
2025-01-08T15:20:05.334Z [err] npm error gyp ERR! find Python - "" could not be run
2025-01-08T15:20:05.334Z [err] npm error gyp ERR! find Python Python is not set from environment variable PYTHON
2025-01-08T15:20:05.334Z [err] npm error gyp ERR! find Python checking if "python3" can be used
2025-01-08T15:20:05.334Z [err] npm error gyp ERR! find Python checking if "python" can be used
2025-01-08T15:20:05.334Z [err] npm error gyp ERR! find Python **********************************************************
2025-01-08T15:20:05.334Z [err] npm error gyp ERR! find Python You need to install the latest version of Python.
2025-01-08T15:20:05.334Z [err] npm error gyp ERR! find Python Node-gyp should be able to find and use Python. If not,
2025-01-08T15:20:05.334Z [err] npm error gyp ERR! find Python you can try one of the following options:
2025-01-08T15:20:05.334Z [err] npm error gyp ERR! find Python - Use the switch --python="/path/to/pythonexecutable"
2025-01-08T15:20:05.334Z [err] npm error gyp ERR! find Python (accepted by both node-gyp and npm)
2025-01-08T15:20:05.334Z [err] npm error gyp ERR! find Python - Set the environment variable PYTHON
2025-01-08T15:20:05.334Z [err] npm error gyp ERR! find Python - Set the npm configuration variable python:
2025-01-08T15:20:05.334Z [err] npm error gyp ERR! find Python npm config set python "/path/to/pythonexecutable"
2025-01-08T15:20:05.334Z [err] npm error gyp ERR! find Python For more information consult the documentation at:
2025-01-08T15:20:05.334Z [err] npm error gyp ERR! find Python https://github.com/nodejs/node-gyp#installation
2025-01-08T15:20:05.334Z [err] npm error gyp ERR! configure error
2025-01-08T15:20:05.334Z [err] npm error gyp ERR! stack Error: Could not find any Python installation to use
2025-01-08T15:20:05.334Z [err] npm error gyp ERR! stack at PythonFinder.fail (/config/node_modules/node-gyp/lib/find-python.js:306:11)
2025-01-08T15:20:05.334Z [err] npm error gyp ERR! stack at PythonFinder.findPython (/config/node_modules/node-gyp/lib/find-python.js:164:17)
2025-01-08T15:20:05.334Z [err] npm error gyp ERR! stack at process.processTicksAndRejections (node:internal/process/task_queues:105:5)
2025-01-08T15:20:05.334Z [err] npm error gyp ERR! stack at async configure (/config/node_modules/node-gyp/lib/configure.js:27:18)
2025-01-08T15:20:05.334Z [err] npm error gyp ERR! stack at async run (/config/node_modules/node-gyp/bin/node-gyp.js:81:18)
2025-01-08T15:20:05.334Z [err] npm error gyp ERR! System Linux 6.6.66-haos
2025-01-08T15:20:05.334Z [err] npm error gyp ERR! command "/usr/bin/node" "/config/node_modules/.bin/node-gyp" "rebuild"
2025-01-08T15:20:05.334Z [err] npm error gyp ERR! cwd /config/node_modules/socketcan
2025-01-08T15:20:05.334Z [err] npm error gyp ERR! node -v v22.11.0
2025-01-08T15:20:05.334Z [err] npm error gyp ERR! node-gyp -v v11.0.0
2025-01-08T15:20:05.334Z [err] npm error gyp ERR! not ok
2025-01-08T15:20:05.336Z [err] npm error A complete log of this run can be found in: /root/.npm/_logs/2025-01-08T15_19_56_613Z-debug-0.log
2025-01-08T15:20:05.350Z rc=1
Vincèn
