Hi Forum, i installed this before, but i cant write the correct code:
The commands here: : https://home-assistant.io/docs/installation/virtualenv/ are working great.
When i write the script: Daemon script in: /etc/init.d/hass-daemon i change this: RUN_AS=“USER” to RUN_AS=“homeassistant”
meaby the config_dir should be changed, but what information should i put here:
this: /var/opt/homeassistant or /home/homeassistant/.homeassistant
Hope you can help me, with this, setup again.
I got this working before, but now its not working.
