If i try to install libscrc in HA on my Raspberry pi3 i obatin the error shown below, can you help me?
Command executed: pip3 install libscrc: 1
Collecting libscrc
Using cached libscrc-1.8.1.tar.gz (41 kB)
Preparing metadata (setup.py): started
Preparing metadata (setup.py): finished with status done
Requirement already satisfied: wheel in /usr/lib/python3.10/site-packages (from libscrc) (0.40.0)
Building wheels for collected packages: libscrc
Building wheel for libscrc (setup.py): started
Building wheel for libscrc (setup.py): finished with status error
Running setup.py clean for libscrc
Failed to build libscrc
Installing collected packages: libscrc
Running setup.py install for libscrc: started
Running setup.py install for libscrc: finished with status error
error: subprocess-exited-with-error
× python setup.py bdist_wheel did not run successfully.
│ exit code: 1
╰─> [37 lines of output]
running bdist_wheel
running build
running build_py
creating build
creating build/lib.linux-aarch64-3.10
creating build/lib.linux-aarch64-3.10/libscrc
copying libscrc/_crc82.py → build/lib.linux-aarch64-3.10/libscrc
copying libscrc/init.py → build/lib.linux-aarch64-3.10/libscrc
running egg_info
writing libscrc.egg-info/PKG-INFO
writing dependency_links to libscrc.egg-info/dependency_links.txt
writing requirements to libscrc.egg-info/requires.txt
writing top-level names to libscrc.egg-info/top_level.txt
reading manifest file libscrc.egg-info/SOURCES.txt
reading manifest template MANIFEST.in
warning: manifest_maker: MANIFEST.in, line 2: recursive-include expects …
writing manifest file libscrc.egg-info/SOURCES.txt
creating build/lib.linux-aarch64-3.10/libscrc/plugins
copying libscrc/plugins/convert.py -> build/lib.linux-aarch64-3.10/libscrc/plugins
creating build/lib.linux-aarch64-3.10/libscrc/test
copying libscrc/test/canx.py -> build/lib.linux-aarch64-3.10/libscrc/test
copying libscrc/test/crc16.py -> build/lib.linux-aarch64-3.10/libscrc/test
copying libscrc/test/crc24.py -> build/lib.linux-aarch64-3.10/libscrc/test
copying libscrc/test/crc32.py -> build/lib.linux-aarch64-3.10/libscrc/test
copying libscrc/test/crc64.py -> build/lib.linux-aarch64-3.10/libscrc/test
copying libscrc/test/crc8.py -> build/lib.linux-aarch64-3.10/libscrc/test
copying libscrc/test/crcx.py -> build/lib.linux-aarch64-3.10/libscrc/test
copying libscrc/test/hacker.py -> build/lib.linux-aarch64-3.10/libscrc/test
copying libscrc/test/modbus.py -> build/lib.linux-aarch64-3.10/libscrc/test
running build_ext
building libscrc._crcx extension
creating build/temp.linux-aarch64-3.10
creating build/temp.linux-aarch64-3.10/src
creating build/temp.linux-aarch64-3.10/src/crcx
gcc -Wno-unused-result -Wsign-compare -DNDEBUG -g -fwrapv -O3 -Wall -g -g -g -DTHREAD_STACK_SIZE=0x100000 -fPIC -Isrc/crcx -I/usr/include/python3.10 -c src/crcx/_crcxmodule.c -o build/temp.linux-aarch64-3.10/src/crcx/_crcxmodule.o
error: command gcc failed: No such file or directory
[end of output]
note: This error originates from a subprocess, and is likely not a problem with pip.
ERROR: Failed building wheel for libscrc
× Running setup.py install for libscrc did not run successfully.
│ exit code: 1
╰─> [39 lines of output]
running install
/usr/lib/python3.10/site-packages/setuptools/command/install.py:34: SetuptoolsDeprecationWarning: setup.py install is deprecated. Use build and pip and other standards-based tools.
warnings.warn(
running build
running build_py
creating build
running egg_info
running build_ext
[end of output]
error: legacy-install-failure
× Encountered error while trying to install package.
╰─> libscrc
note: This is an issue with the package mentioned above, not pip.
hint: See above for output from the failure.
