Same issues as you explained. And your workaround solve my issue!
Thank you very much !!
Funny, for me it was the other way around! Tried without the dashes and did not work, with dashes it does. Guess it’s a matter of trying
I can connect and import the devices that are linked in my Somfy Connectivity Kit by using HomeKit Device. However, there is 1 device that isn’t integrated, that is the motor that opens and close my Velux window. I see that device in the app of Somfy, but not in the HomeKit integration…
Does anyone know how to solve it, I already tried to reload it, still not imported…
See Overkiz - Home Assistant. Not all devices are supported via HomeKit natively.
Sorry, Overkiz is very cumbersome. I’m not able to create a local API (Because I dont have any option to enable developer mode on my Connectivity Kit, see many people said the same in above anwsers), and I’m also not able to create a cloud account of OverKiz. (For creating a cloud account, you need to install the app I guess, but it’s not available in the store).
So I cannot install the integration in hass
Indeed, the connectivity kit does not support the Somfy TaHoma Developer Mode (aka local api). The TaHoma by Somfy app should be available in your app store and allow you to leverage the Cloud API.
I tried to use the username / password I use to connect to the app and the web Se connecter
I used the option cloud API option but still does not work and get the failed to connect message. I m really stuck now. I cannot choose Local API because i Use the Somfy Connectivity Kit
