Installation of ZHA in docker environment
Hi
I am trying to setup ZHA with a Sonoff Zigbee 3.0 USB dongle Plus stick. No luck.
My HA instance is running in a docker-compose environment with the following setup.
First I am adding ZHA
This gives the following result
stag2
Accepting gives this as next step and I selecting ZNP
After saving I get this menu as result.
And finally
The red error text says “Unable to connect to ZHA device”
Somewhere, something must be wrong, I am unable to see it, after hours googling and trying different approaches found on internet.
Any fresh eyes that can help?
Try adding
privileged: true
and maybe adding the usb device.
Here is my compose file for reference as I also have the same Zigbee device…
version: '3.3'
services:
    home-assistant:
        privileged: true
        restart: always
        container_name: home-assistant
        volumes:
            - /home/pcwii/homeassistant:/config
            - /var/run/docker.sock:/var/run/docker.sock
            - /dev/serial/by-id:/dev/serial/by-id
            - /run/dbus:/run/dbus:ro
        environment:
            - TZ=america/toronto
            - PUID=1000
            - PGID=1000
            - UMASK=007
        devices:
            - /dev/ttyUSB0:/dev/ttyUSB0
            - /dev/ttyUSB1:/dev/ttyUSB1
        network_mode: host
        image: homeassistant/home-assistant:stable
        logging:
            options:
                max-size: "10m"
May i ask offtopic for what kind of integration do you use access to Docker socket (/var/run/docker.sock:/var/run/docker.sock)? Thank you.
Monitor docker.
