Installation on Fujitsu S740 not successful
I am struggeling to get HAOS installed. With a growing system over time my RasPi3 is too small and will be replaced by a Fujitsu S740 barebone.
And that’s where I am stuck: even with all hints the booting from the SSD fails, the SSD does not show up in the boot manager. I installed HAOS by Debian Live with Etcher. Tried the hint from the HA homepage about the efibootmgr, after the change the bootmanager shows an additional entry, but it is gone after reboot.
What am I missing? Would appreciate any help!
Good morning,
Topic solved: I did not copy the BIOS command from the HAOS installation page correctly… stupid!
Can you tell me how you installed it on Futro S740? Or can you send the correct installation page?
After struggling 5 days in sorting out how to install HAOS on my FutroS760 it turned out that none of the descriped solutions worked except the one booting from Clonezilla and cloneing the HAOS located on a nother stick towards the internal SDD. Thank you so much for this hint.
