Installation on Khadas Vim3
Hello !
I’m unable to boot HomeAssistant on VIM3 or VIM3L :frowning:
I flashed the image from github for the VIM3 on my USB drive using balenaEtcher.
On VIM3, I’m stuck on bootlogo
On VIM3L, I’m having bootloop
Any advice ?
Thanks :v:
It depends on what you have inside emmc.
If you still have Android in eMMC then you might have to enter into maskrom mode to ignore emmc boot and let it from usb or sdcard.
You can check. khadas documentation on how to enter into. Maskrom mode.
Please don’t use vim3 image on vim3l it will not work.
Good luck.
Is the NPU in Vim3 Pro available to HASS?
Manual?
My setup consist of HASS (with Google Coral accelerator) installed on Raspberry pi 4.
The plan is to move the setup to Vim3.
It would be nice to be able to use its NPU together with the coral.
The goal is to implement ASR AND object recognition. In other words to be able to get more TOPS.
Thank you
Fritz
Cog.Sci
Umeå
Sween
Hi All,
Just a question. I intalled haos to vim3, just doesn`t work the wifi :frowning: how can I set it?
