I followed this guide to install HA on a Mac Mini but got a bunch of errors.
Could someone please point me in the right direction as to what went wrong?
This message is generated by the introduction component. You can
disable it in configuration.yaml.
2019-03-21 20:51:09 INFO (MainThread) [homeassistant.loader] Loaded persistent_notification from homeassistant.components.persistent_notification
2019-03-21 20:51:09 INFO (MainThread) [homeassistant.setup] Setup of domain introduction took 0.0 seconds.
2019-03-21 20:51:09 INFO (MainThread) [homeassistant.setup] Setting up lovelace
2019-03-21 20:51:09 INFO (MainThread) [homeassistant.setup] Setup of domain lovelace took 0.0 seconds.
2019-03-21 20:51:09 ERROR (MainThread) [homeassistant.setup] Unable to set up dependencies of api. Setup failed for dependencies: http
2019-03-21 20:51:09 ERROR (MainThread) [homeassistant.setup] Setup failed for api: Could not set up all dependencies.
2019-03-21 20:51:09 ERROR (MainThread) [homeassistant.setup] Unable to set up dependencies of websocket_api. Setup failed for dependencies: http
2019-03-21 20:51:09 ERROR (MainThread) [homeassistant.setup] Setup failed for websocket_api: Could not set up all dependencies.
2019-03-21 20:51:09 ERROR (MainThread) [homeassistant.setup] Unable to set up dependencies of auth. Setup failed for dependencies: http
2019-03-21 20:51:09 ERROR (MainThread) [homeassistant.setup] Setup failed for auth: Could not set up all dependencies.
2019-03-21 20:51:09 ERROR (MainThread) [homeassistant.setup] Unable to set up dependencies of onboarding. Setup failed for dependencies: auth, http
2019-03-21 20:51:09 ERROR (MainThread) [homeassistant.setup] Setup failed for onboarding: Could not set up all dependencies.
2019-03-21 20:51:09 ERROR (MainThread) [homeassistant.setup] Unable to set up dependencies of frontend. Setup failed for dependencies: api, websocket_api, http, system_log, auth, onboarding
2019-03-21 20:51:09 ERROR (MainThread) [homeassistant.setup] Setup failed for frontend: Could not set up all dependencies.
2019-03-21 20:51:09 INFO (SyncWorker_2) [homeassistant.util.package] Attempting install of sqlalchemy==1.2.18
2019-03-21 20:51:28 INFO (MainThread) [homeassistant.setup] Setting up recorder
Exception in thread Recorder:
File "/Library/Frameworks/Python.framework/Versions/3.7/lib/python3.7/threading.py", line 917, in _bootstrap_inner
self.run()
File "/Library/Frameworks/Python.framework/Versions/3.7/lib/python3.7/site-packages/homeassistant/components/recorder/__init__.py", line 171, in run
from .models import States, Events
File "/Library/Frameworks/Python.framework/Versions/3.7/lib/python3.7/site-packages/homeassistant/components/recorder/models.py", line 6, in <module>
from sqlalchemy import (
ModuleNotFoundError: No module named 'sqlalchemy'
2019-03-21 20:51:38 WARNING (MainThread) [homeassistant.setup] Setup of recorder is taking over 10 seconds.
