Seems there has been a few threads here trying to do this with mixed results. I have figured out exactly what is going on and why there is a lot of confusion.
The XU4 can boot in two modes, from a SD card, or from eMMC.
When booting from SD, it loads u-boot from the SD card, which resides in the first 4MB of the image and life is good.
When booting from eMMC, it loads u-boot from a protected/hidden block on the device, which if you have never updated it, is from 2017 and is missing support for squashfs, and a few required commands such as fileenv
The HAOS not only requires fileenv, it also puts the kernel image (zImage) in partition 5, which is a squashfs filesystem.
If like me, you are using the eMMC->Flash adapter ODROID provided with these devices, you can not access the hidden boot block on the device to update it.
The solution thankfully is not too hard.
- As per normal, write the HAOS image to both the eMMC AND a sd-card.
- Set the odriod to boot off sd-card and install both the eMMC and sd-card.
- Boot HAOS, and when presented with the prompt switch to the next tty (Alt+Right), login as
root, no password should be required - Unlock the boot block on the eMMC so we can update it:
echo 0 > /sys/block/mmcblk0boot0/force_ro - Copy the updated uboot from the HAOS image on the eMMC to the boot block
dd if=/dev/mmcblk0 of=/dev/mmcblk0boot0 bs=512 skip=1 - Shutdown and unplug the power from the device
poweroff - Remove the sd-card and change the switch to boot from eMMC
It should now properly boot with the version of u-boot that HAOS is distributing with the image.
If you have the UART connected you should see something similar to the following, noting the U-Boot date is current:
U-Boot 2025.01 (Sep 08 2025 - 17:04:25 +0000) for ODROID-XU3/XU4/HC1/HC2
DRAM: 2 GiB
Core: 72 devices, 12 uclasses, devicetree: separate
MMC: mmc@12200000: 0, mmc@12220000: 2
Loading Environment from MMC... Reading from MMC(0)... *** Warning - bad CRC, using default environment
Loading Environment from nowhere... OK
In: serial
Out: serial
Err: serial
Model: Odroid XU3/XU4/HC1/HC2 based on Exynos5422
Type: xu4
Boot device: MMC(0)
Net: No ethernet found.
Card did not respond to voltage select! : -110
MMC Device 1 not found
no mmc device at slot 1
switch to partitions #0, OK
mmc0(part 0) is current device
Scanning mmc 0:1...
Found U-Boot script /boot.scr
2683 bytes read in 2 ms (1.3 MiB/s)
## Executing script at 50000000
loading env...
MMC read: dev # 0, block # 1222656, count 32 ... 32 blocks read: OK
36 bytes read in 1 ms (35.2 KiB/s)
65191 bytes read in 4 ms (15.5 MiB/s)
Working FDT set to 43000000
Trying to boot slot A, 2 attempts remaining. Loading kernel ...
11891312 bytes read in 520 ms (21.8 MiB/s)
storing env...
MMC write: dev # 0, block # 1222656, count 32 ... 32 blocks written: OK
bootargs=zram.enabled=1 zram.num_devices=3 systemd.machine_id=019776a0cdff42469110bdcd5c5fdbfe fsck.repair=yes root=PARTUUID=48617373-06
ro rootwait rauc.slot=A console=ttySAC2,115200 console=tty0
Starting kernel
Kernel image @ 0x42000000 [ 0x000000 - 0xb57270 ]
## Flattened Device Tree blob at 43000000
Booting using the fdt blob at 0x43000000
Loading Device Tree to 4ffed000, end 4ffffea6 ... OK
Working FDT set to 4ffed000
Starting kernel ...
[ 0.000000] Booting Linux on physical CPU 0x100
