I’ve been trying to create a new virtual box (Oracle virtual box Version 6.1.18 r142142 (Qt5.6.2) on a Windows 10 laptop using the hassos_ova-5.13.vdi file. Every time I try I get an error :“FATAL: No bootable medium found…” . This happens on 2 separate Window machine both with IDE hard drives. This has been happening for about 3 days, any ideas how to fix this and set up HA again?
Thanks in advance!
Couldn’t get it to work after a few days of trying. Setting it up on a pi now.
Make sure you’ve selected “Enable EFI (special OSes only)” under the System settings, and the “Bridged Adapter” as the “Attached to” under Network. Neither is the default, and both are needed for the VM tp boot correctly.
That did it! Thanks!
