I’m new to Home Assistant and flashed the RP3 image onto a 32 GB SD card, then plugged it into an RP3. (This is an RP3 I used in the past for home automation using Heyu; it was always reliable.) After waiting a few minutes, I connected to X.X.X.X:8123 and saw the “Preparing Home Assistant” page. Per the instructions, I waited 20 minutes, but nothing happened. After 1 hour I clicked the pulsating blue dot by luck and got the installation log.
I found several github.com access errors, the first being
ERROR (MainThread) [supervisor.store.git] Can't clone https://github.com/home-assistant/addons repository: Cmd('git') failed due to: exit code(128)
cmdline: git clone -v --recursive --depth=1 --shallow-submodules https://github.com/home-assistant/addons /data/addons/core
I copied that commandline my linux workstation, which is plugged into the same router as the RP3, and it worked just fine.
I’ve tried reflashing the SD card several times. I put explicit DNS addresses into my router. The results are identical. At this point, I’m not sure what I can do to resolve the issue.
Thanks in advance for any suggestions.
–Michael
