kotrfa
October 17, 2022, 5:24pm
1
I am stuck with my installation - it just stops at the line:
[supervisor.resolution.fixup] System autofix complete
and hangs there forever (more than 20+ minutes). I tried two different SD cards, different networks, etc. nothing works. I am connected via wifi btw. The supervisor gives:
Home Assistant observer
Supervisor: Connected
Supported: Supported
Healthy: Healthy
but I am still on Preparing Home Assistant
screen. Any hints, please? The full log is below:
s6-rc: info: service s6rc-oneshot-runner: starting
s6-rc: info: service s6rc-oneshot-runner successfully started
s6-rc: info: service fix-attrs: starting
s6-rc: info: service fix-attrs successfully started
s6-rc: info: service legacy-cont-init: starting
cont-init: info: running /etc/cont-init.d/udev.sh
[17:18:54] INFO: Using udev information from host
cont-init: info: /etc/cont-init.d/udev.sh exited 0
s6-rc: info: service legacy-cont-init successfully started
s6-rc: info: service legacy-services: starting
services-up: info: copying legacy longrun supervisor (no readiness notification)
services-up: info: copying legacy longrun watchdog (no readiness notification)
s6-rc: info: service legacy-services successfully started
[17:18:54] INFO: Starting local supervisor watchdog...
22-10-17 17:18:58 INFO (MainThread) [__main__] Initializing Supervisor setup
22-10-17 17:18:59 INFO (MainThread) [supervisor.bootstrap] Initializing Supervisor Sentry
22-10-17 19:18:59 INFO (MainThread) [supervisor.bootstrap] Seting up coresys for machine: raspberrypi3
22-10-17 19:18:59 INFO (SyncWorker_0) [supervisor.docker.supervisor] Attaching to Supervisor ghcr.io/home-assistant/armv7-hassio-supervisor with version 2022.10.0
22-10-17 19:18:59 INFO (SyncWorker_0) [supervisor.docker.supervisor] Connecting Supervisor to hassio-network
22-10-17 19:19:00 INFO (SyncWorker_0) [supervisor.docker.interface] Cleanup images: ['ghcr.io/home-assistant/armv7-hassio-supervisor:2022.09.1']
22-10-17 19:19:08 INFO (MainThread) [supervisor.resolution.evaluate] Starting system evaluation with state CoreState.INITIALIZE
22-10-17 19:19:08 INFO (MainThread) [supervisor.resolution.evaluate] System evaluation complete
22-10-17 19:19:08 INFO (MainThread) [__main__] Setting up Supervisor
22-10-17 19:19:09 INFO (MainThread) [supervisor.api] Starting API on 172.30.32.2
22-10-17 19:19:09 INFO (MainThread) [supervisor.hardware.monitor] Started Supervisor hardware monitor
22-10-17 19:19:09 INFO (MainThread) [supervisor.dbus.manager] Connected to system D-Bus.
22-10-17 19:19:09 INFO (MainThread) [supervisor.dbus.agent] Load dbus interface io.hass.os
22-10-17 19:19:09 INFO (MainThread) [supervisor.dbus.systemd] Load dbus interface org.freedesktop.systemd1
22-10-17 19:19:09 INFO (MainThread) [supervisor.dbus.logind] Load dbus interface org.freedesktop.login1
22-10-17 19:19:09 INFO (MainThread) [supervisor.dbus.hostname] Load dbus interface org.freedesktop.hostname1
22-10-17 19:19:09 INFO (MainThread) [supervisor.dbus.timedate] Load dbus interface org.freedesktop.timedate1
22-10-17 19:19:09 INFO (MainThread) [supervisor.dbus.network] Load dbus interface org.freedesktop.NetworkManager
22-10-17 19:19:09 INFO (MainThread) [supervisor.dbus.rauc] Load dbus interface de.pengutronix.rauc
22-10-17 19:19:09 INFO (MainThread) [supervisor.dbus.resolved] Load dbus interface org.freedesktop.resolve1
22-10-17 19:19:10 INFO (MainThread) [supervisor.host.services] Updating service information
22-10-17 19:19:10 INFO (MainThread) [supervisor.host.sound] Updating PulseAudio information
22-10-17 19:19:10 WARNING (MainThread) [supervisor.host.network] Requested to update interface wlan0 which does not exist or is disabled.
22-10-17 19:19:10 INFO (MainThread) [supervisor.host.apparmor] Loading AppArmor Profiles: {'hassio-supervisor'}
22-10-17 19:19:10 INFO (MainThread) [supervisor.docker.monitor] Started docker events monitor
22-10-17 19:19:10 INFO (SyncWorker_1) [supervisor.docker.interface] Attaching to ghcr.io/home-assistant/armv7-hassio-cli with version 2022.08.0
22-10-17 19:19:11 INFO (SyncWorker_1) [supervisor.docker.interface] Attaching to ghcr.io/home-assistant/armv7-hassio-dns with version 2022.04.1
22-10-17 19:19:11 INFO (MainThread) [supervisor.plugins.dns] Updated /etc/resolv.conf
22-10-17 19:19:11 INFO (SyncWorker_1) [supervisor.docker.interface] Attaching to ghcr.io/home-assistant/armv7-hassio-audio with version 2022.07.0
22-10-17 19:19:11 INFO (SyncWorker_1) [supervisor.docker.interface] Attaching to ghcr.io/home-assistant/armv7-hassio-observer with version 2021.10.0
22-10-17 19:19:11 INFO (SyncWorker_1) [supervisor.docker.interface] Attaching to ghcr.io/home-assistant/armv7-hassio-multicast with version 2022.02.0
22-10-17 19:19:11 INFO (MainThread) [supervisor.updater] Fetching update data from https://version.home-assistant.io/stable.json
22-10-17 19:19:12 INFO (MainThread) [supervisor.homeassistant.secrets] Loaded 0 Home Assistant secrets
22-10-17 19:19:12 INFO (SyncWorker_0) [supervisor.docker.interface] Attaching to ghcr.io/home-assistant/raspberrypi3-homeassistant with version landingpage
22-10-17 19:19:12 INFO (MainThread) [supervisor.homeassistant.core] Starting HomeAssistant landingpage
22-10-17 19:19:12 INFO (MainThread) [supervisor.os.manager] Detect Home Assistant Operating System 9.2 / BootSlot A
22-10-17 19:19:13 INFO (MainThread) [supervisor.store.git] Loading add-on /data/addons/git/5c53de3b repository
22-10-17 19:19:13 INFO (MainThread) [supervisor.store.git] Loading add-on /data/addons/git/a0d7b954 repository
22-10-17 19:19:13 INFO (MainThread) [supervisor.store.git] Loading add-on /data/addons/core repository
22-10-17 19:19:14 INFO (MainThread) [supervisor.store] Loading add-ons from store: 67 all - 67 new - 0 remove
22-10-17 19:19:14 INFO (MainThread) [supervisor.addons] Found 0 installed add-ons
22-10-17 19:19:14 INFO (MainThread) [supervisor.backups.manager] Found 0 backup files
22-10-17 19:19:14 INFO (MainThread) [supervisor.discovery] Loaded 0 messages
22-10-17 19:19:14 INFO (MainThread) [supervisor.ingress] Loaded 0 ingress sessions
22-10-17 19:19:14 INFO (MainThread) [supervisor.resolution.check] Starting system checks with state CoreState.SETUP
22-10-17 19:19:14 INFO (MainThread) [supervisor.resolution.check] System checks complete
22-10-17 19:19:14 INFO (MainThread) [supervisor.resolution.evaluate] Starting system evaluation with state CoreState.SETUP
22-10-17 19:19:14 INFO (MainThread) [supervisor.resolution.evaluate] System evaluation complete
22-10-17 19:19:14 INFO (MainThread) [supervisor.jobs] 'ResolutionFixup.run_autofix' blocked from execution, system is not running - CoreState.SETUP
22-10-17 19:19:14 INFO (MainThread) [__main__] Running Supervisor
22-10-17 19:19:14 INFO (MainThread) [supervisor.os.manager] Rauc: A - marked slot kernel.0 as good
22-10-17 19:19:14 INFO (MainThread) [supervisor.addons] Phase 'AddonStartup.INITIALIZE' starting 0 add-ons
22-10-17 19:19:14 INFO (MainThread) [supervisor.addons] Phase 'AddonStartup.SYSTEM' starting 0 add-ons
22-10-17 19:19:14 INFO (MainThread) [supervisor.addons] Phase 'AddonStartup.SERVICES' starting 0 add-ons
22-10-17 19:19:14 INFO (MainThread) [supervisor.core] Skiping start of Home Assistant
22-10-17 19:19:14 INFO (MainThread) [supervisor.addons] Phase 'AddonStartup.APPLICATION' starting 0 add-ons
22-10-17 19:19:14 INFO (MainThread) [supervisor.misc.tasks] All core tasks are scheduled
22-10-17 19:19:14 INFO (MainThread) [supervisor.core] Supervisor is up and running
22-10-17 19:19:14 INFO (MainThread) [supervisor.homeassistant.core] Home Assistant setup
22-10-17 19:19:14 INFO (MainThread) [supervisor.host.info] Updating local host information
22-10-17 19:19:14 INFO (SyncWorker_0) [supervisor.docker.interface] Updating image ghcr.io/home-assistant/raspberrypi3-homeassistant:landingpage to ghcr.io/home-assistant/raspberrypi3-homeassistant:2022.10.4
22-10-17 19:19:14 INFO (SyncWorker_0) [supervisor.docker.interface] Downloading docker image ghcr.io/home-assistant/raspberrypi3-homeassistant with tag 2022.10.4.
22-10-17 19:19:14 INFO (MainThread) [supervisor.resolution.check] Starting system checks with state CoreState.RUNNING
22-10-17 19:19:14 INFO (MainThread) [supervisor.resolution.checks.base] Run check for IssueType.DNS_SERVER_IPV6_ERROR/ContextType.DNS_SERVER
22-10-17 19:19:14 INFO (MainThread) [supervisor.resolution.checks.base] Run check for IssueType.PWNED/ContextType.ADDON
22-10-17 19:19:14 INFO (MainThread) [supervisor.resolution.checks.base] Run check for IssueType.DNS_SERVER_FAILED/ContextType.DNS_SERVER
22-10-17 19:19:14 INFO (MainThread) [supervisor.host.services] Updating service information
22-10-17 19:19:14 INFO (MainThread) [supervisor.host.network] Updating local network information
22-10-17 19:19:14 INFO (MainThread) [supervisor.resolution.checks.base] Run check for IssueType.FREE_SPACE/ContextType.SYSTEM
22-10-17 19:19:14 INFO (MainThread) [supervisor.resolution.checks.base] Run check for IssueType.NO_CURRENT_BACKUP/ContextType.SYSTEM
22-10-17 19:19:14 INFO (MainThread) [supervisor.resolution.module] Create new suggestion SuggestionType.CREATE_FULL_BACKUP - ContextType.SYSTEM / None
22-10-17 19:19:14 INFO (MainThread) [supervisor.resolution.module] Create new issue IssueType.NO_CURRENT_BACKUP - ContextType.SYSTEM / None
22-10-17 19:19:14 INFO (MainThread) [supervisor.resolution.checks.base] Run check for IssueType.SECURITY/ContextType.CORE
22-10-17 19:19:14 INFO (MainThread) [supervisor.resolution.checks.base] Run check for IssueType.TRUST/ContextType.SUPERVISOR
22-10-17 19:19:15 INFO (MainThread) [supervisor.host.manager] Host information reload completed
22-10-17 19:19:17 INFO (MainThread) [supervisor.resolution.checks.base] Run check for IssueType.IPV4_CONNECTION_PROBLEM/ContextType.SYSTEM
22-10-17 19:19:17 INFO (MainThread) [supervisor.resolution.check] System checks complete
22-10-17 19:19:17 INFO (MainThread) [supervisor.resolution.evaluate] Starting system evaluation with state CoreState.RUNNING
22-10-17 19:19:19 INFO (MainThread) [supervisor.resolution.evaluate] System evaluation complete
22-10-17 19:19:19 INFO (MainThread) [supervisor.resolution.fixup] Starting system autofix at state CoreState.RUNNING
22-10-17 19:19:19 INFO (MainThread) [supervisor.resolution.fixup] System autofix complete
kotrfa
October 17, 2022, 6:41pm
2
Solved. It just tooks much longer apparently on my RPI3.
Can you say how long? I’m also using an RPI3, and mine has been sitting for two hours now with no further log messages and no progress.
kotrfa
November 9, 2022, 10:25am
4
In my case it was less than 2 hours
I am sitting here wondering what in the world could be taking it so long…1 hour 30 minutes so far.
I initially had the 500 error on the network because it was autodiscovering the wrong name server. Once that was corrected I finally got the home screen but it is just sitting there on the same thing OP mentioned. I will give it another 30 or so, but that seems wrong…to take so long.
In my case it just loops and loops
That moment when you have the same issue, did not remember you had the issue previously and find your own message in a forum…lol.
It takes longer now. Before it took almost 2 hours, but now it is 2 hours and 20 minutes so far…this is kind of insane. No progress updates, and what is it doing that takes this long?! lol.
sanderjo
(Superkoning)
September 8, 2024, 6:53pm
8
I have got a Raspi2, so I wrote https://github.com/home-assistant/operating-system/releases/download/13.1/haos_rpi2-13.1.img.xz to an SDcard … and “Preparing Home Assistant” is now taking a few hours.
Hopefully a nice result tomorrow morning … fingers crossed …
EDIT: already there! Not bad for a raspi 2 (from 2015) … 2-3 hours.
mattimac
(chandler)
October 1, 2024, 7:18pm
9
raspberry pi 3 B , same issue for 40 mins now…
Raspi3b here, with a TF card with I/O speed up to 180MB/s, it tooks about 20 mins.
danir.de
(Danir)
January 20, 2025, 7:03pm
11
Takes ages. Even on a AMD EPYC server it takes multiple hours.
PANDAJSR
(Pandajsr)
April 5, 2025, 4:24am
12
I thing it`s just too slow, i have the same issue in Workstation(Win)
opened 03:06PM - 05 Oct 23 UTC
closed 03:12PM - 05 Oct 23 UTC
bug
### Describe the issue you are experiencing
Always stuck in[supervisor.resoluti… on.fixup] System autofix complete
[supervisor.docker.network] Can't find Supervisor network, creating a new network
[supervisor.bootstrap] Seting up coresys for machine: generic-x86-64
[supervisor.docker.supervisor] Attaching to Supervisor ghcr.io/home-assistant/amd64-hassio-supervisor with version 2023.10.0
[supervisor.resolution.evaluate] Starting system evaluation with state initialize
[supervisor.docker.interface] Found ghcr.io/home-assistant/amd64-hassio-cli versions: []
[supervisor.docker.interface] Attaching to ghcr.io/home-assistant/amd64-hassio-cli with version 2023.06.0
[supervisor.plugins.cli] Starting CLI plugin
[supervisor.docker.cli] Starting CLI ghcr.io/home-assistant/amd64-hassio-cli with version 2023.06.0 - 172.30.32.5
[supervisor.docker.interface] Found ghcr.io/home-assistant/amd64-hassio-dns versions: []
[supervisor.docker.interface] Attaching to ghcr.io/home-assistant/amd64-hassio-dns with version 2023.06.2
[supervisor.plugins.dns] Starting CoreDNS plugin
[supervisor.docker.dns] Starting DNS ghcr.io/home-assistant/amd64-hassio-dns with version 2023.06.2 - 172.30.32.3
[supervisor.docker.interface] Found ghcr.io/home-assistant/amd64-hassio-audio versions: []
[supervisor.docker.interface] Attaching to ghcr.io/home-assistant/amd64-hassio-audio with version 2023.06.0
[supervisor.plugins.audio] Starting Audio plugin
[supervisor.docker.audio] Starting Audio ghcr.io/home-assistant/amd64-hassio-audio with version 2023.06.0 - 172.30.32.4
[supervisor.docker.interface] Found ghcr.io/home-assistant/amd64-hassio-observer versions: []
[supervisor.docker.interface] Attaching to ghcr.io/home-assistant/amd64-hassio-observer with version 2023.06.0
[supervisor.plugins.observer] Starting observer plugin
[supervisor.docker.observer] Starting Observer ghcr.io/home-assistant/amd64-hassio-observer with version 2023.06.0 - 172.30.32.6
[supervisor.docker.interface] Found ghcr.io/home-assistant/amd64-hassio-multicast versions: []
[supervisor.docker.interface] Attaching to ghcr.io/home-assistant/amd64-hassio-multicast with version 2023.06.2
[supervisor.plugins.multicast] Starting Multicast plugin
[supervisor.docker.multicast] Starting Multicast ghcr.io/home-assistant/amd64-hassio-multicast with version 2023.06.2 - Host
[supervisor.docker.interface] No version found for ghcr.io/home-assistant/generic-x86-64-homeassistant
[supervisor.homeassistant.core] No Home Assistant Docker image ghcr.io/home-assistant/generic-x86-64-homeassistant found.
[supervisor.docker.interface] Attaching to ghcr.io/home-assistant/generic-x86-64-homeassistant with version landingpage
[supervisor.homeassistant.core] Using preinstalled landingpage
[supervisor.homeassistant.module] Update pulse/client.config: /data/tmp/homeassistant_pulse
[supervisor.docker.homeassistant] Starting Home Assistant ghcr.io/home-assistant/generic-x86-64-homeassistant with version landingpage
[supervisor.os.manager] Detect Home Assistant Operating System 11.0.rc1 / BootSlot A
[supervisor.store.git] Cloning add-on https://github.com/esphome/home-assistant-addon repository
[supervisor.store.git] Cloning add-on https://github.com/home-assistant/addons repository
[supervisor.store.git] Cloning add-on https://github.com/hassio-addons/repository repository
[supervisor.store] Loading add-ons from store: 72 all - 72 new - 0 remove
[supervisor.resolution.check] Starting system checks with state setup
[supervisor.resolution.evaluate] Starting system evaluation with state setup
[supervisor.jobs] 'ResolutionFixup.run_autofix' blocked from execution, system is not running - setup
[supervisor.addons] Phase 'initialize' starting 0 add-ons
[supervisor.addons] Phase 'system' starting 0 add-ons
[supervisor.addons] Phase 'services' starting 0 add-ons
[supervisor.addons] Phase 'application' starting 0 add-ons
[supervisor.docker.interface] Updating image ghcr.io/home-assistant/generic-x86-64-homeassistant:landingpage to ghcr.io/home-assistant/generic-x86-64-homeassistant:2023.10.0
[supervisor.docker.interface] Downloading docker image ghcr.io/home-assistant/generic-x86-64-homeassistant with tag 2023.10.0.
[supervisor.resolution.check] Starting system checks with state running
[supervisor.resolution.checks.base] Run check for ipv4_connection_problem/system
[supervisor.resolution.checks.base] Run check for security/core
[supervisor.resolution.checks.base] Run check for free_space/system
[supervisor.resolution.checks.base] Run check for no_current_backup/system
[supervisor.resolution.module] Create new suggestion create_full_backup - system / None
[supervisor.resolution.module] Create new issue no_current_backup - system / None
[supervisor.resolution.checks.base] Run check for multiple_data_disks/system
[supervisor.resolution.checks.base] Run check for dns_server_failed/dns_server
[supervisor.resolution.checks.base] Run check for pwned/addon
[supervisor.resolution.checks.base] Run check for docker_config/system
[supervisor.resolution.checks.base] Run check for dns_server_ipv6_error/dns_server
[supervisor.resolution.checks.base] Run check for trust/supervisor
[supervisor.resolution.evaluate] Starting system evaluation with state running
[supervisor.resolution.fixup] Starting system autofix at state running
### What operating system image do you use?
generic-x86-64 (Generic UEFI capable x86-64 systems)
### What version of Home Assistant Operating System is installed?
6.6
### Did you upgrade the Operating System.
Yes
### Steps to reproduce the issue
1.
2.
3.
Always stuck in[supervisor.resolution.fixup] System autofix complete
### Anything in the Supervisor logs that might be useful for us?
```txt
### Anything in the Host logs that might be useful for us?
```txt
### System information
### Additional information
PANDAJSR
(Pandajsr)
April 5, 2025, 5:20am
13
mabe wate fel hours
等一个多个小时了还没好
kur1k0
(Rachel)
July 29, 2025, 1:09am
14
just leave it alone, everything is gonna be fine
I would suspect that the reason it is so slow is that, because of the small RAM (1GB), there is a lot of disk swapping (virtual memory; SD card acting as an extension of RAM)
A functional RPi 3B+ is about US$50 (no case). Consider a refurbished tower PC for about US$90:
Faster CPU
8x RAM
30x hard drive
case
well supported OS (Ubuntu)
can run other programs when HAOS is installed in a virtual machine
Downsides
Energy consumption: 24W (RPi is 5-10W)
No embedded I/O (This could be resolved with an Arduino Nano --8 digital, 8 analog, SPI-- and MySensors for US$2.50 )
A lot bigger!
Using USB ports in HAOS is do-able, though a small challenge.
