@gerograf
i think you choose the correct usb-device. In HA you have to go to your addon and then to the configuration tab. I hope there you can configure your device. Under device click on the right side the triangle and choose your usb-path.
On my zwave js configuration it was a similar cryptic device path.
Please excuse my poor english.
Your english is very good, am I italian, so itās fine!
I know what you mean, but there is no add for this particulate matter device, but a native integration in HA, so no addon GUI to use to configure it when runnin g under VMM.
Letās see whether anyone here can help with this request about accessing USB device from the VMM environment.
My other USB device is a ConBee II stick working well, in the add GUI I can select it directly.
@gerosaf
it may be possible to find your hardware go to the supervisor dashboard, then click on the tab system on the upper right side. Look for host. There you can find three dots on the lower right side. Click on this and choose hardware. I think in earlier Version it was simple to find the right usb. Now it is horrible. When i read the instruction serial particulate matter, i think you have to configure it in config.yaml. On the other hand you have to search for it in the internet. I have found this here:
Another question appeared to me: if/when Synology shuts down or reboots (power failure, SW upgradeā¦) what happens with HA installation inside VM ? Does synology shuts down HA (and VM) correctly or is it āuncleanā shutdown (and possibility of corrupting whole thing)?
Hi @Protoncek
there is an option in VMM where you decide if suspend or shutdown the VM when Syno is restarting or shutting down.
Canāt answer what happen in case of power failure of Syno
Super helpful! Thank you! I managed to migrate off of Synologyās old broken Docker version and everything seems to be working correctly after a restore.
@gerosaf:thanks , i found it and set to suspend, i guess itās the best option. Ok, if all ok syno should shut down by itself before UPS batteries die, but i canāt help wondering āwhat ifā¦ā
Does getting HA inside a VM to connect to a database outside the VM really make things faster ?!
I think maria db engine is much faster than internal db. I installed outside of the VM to take advantadge of the 2 corrs of the system (my vm is limited to 1). But installing maria db in the VM with the official supervisor plugin should also make a difference.
Can I install supervised version if I use Synology VM?
If yes, I can get rid of docker and get some more benefits out the Synology NAS.
I also need to buy some more RAMās as I only have 2 GB
@nicolae.fratila : yes, thatās what i did. No more docker, but you really need to upgrade ram first.
@mrbrett i installed mariadb, but for now i went back to ānormalā, because strange thing happened: all data WAS recording into new database, but i have one sql sensor, which pulls out MIN and MAX temperature within 14 hours from āstatesā of database, and after i switched to mariadb this sql still kept publising data from old database. When i deleted old database it was recreated at HA restart . So, i must be missing somethingā¦
Hi, Fredrik Erlandsson. First of all, congrats for this great job.
Iād like to know if an OS upgrade (from 5.11 to 5.12) may cause any problem. Iām using the patched OVA you created.
Everything is flawless so far.
No upgrades within my patched ova will not cause any problems (Iām running 5.12 myself without issues).
The 5.13 version of the ova will have my patch integrated but I donāt know the release date for that. My patch makes Synology VMM recognize the guest tools so the virtual machine can be shutdown gracefully (among other things), changing stuff within that vmm will not have any effect.
Thanks a lot for the guide - as well as for the package in the past! Iām also switching to VM (after a NAS upgrade) in order to keep things simple.
Almost everything working after a couple of attempts. Only one probleme: my VM gets the IP from DHCP - and I can access HA from that DynamicIP:8123. It works perfectly. I expected it to be accessible also on http://homeassistant.local:8123 - but this si not working.
What did I miss? where should I configure the local domain? It would help when I get to SSL and remote access via reverse proxy (not there yet!)
Tks
In Supervisor - System tab, change it to fixed IP address. You will need it in future, especially if you plan on reverse proxy/external access.
In regard to homeassistant.local - did you try without .local at the end?
Thanks - yes, Iāve been able to set this up as fixed IP and that helps of course.
Just wondering where (NAS? HA? VMM?) this .local domain should be configuredā¦ I cannot access neither via homeassistant.local nor via homeassistant.
I included homeassistant.local as āhostnameā in supervisor configuration, but to no effect
This is usually mDNS issue - it can be bunch of things - try searching more about this topic.
One of the most common issues could be using multiple subnets.
Just to say this aloud - if you canāt get access to homeassistant.local or homeassistant, in general this is not an error, and in 99% of cases, this has nothing to do with homeassistant, but is related to your home network.
Try āhomeassistant.local:8123ā
But, to be honest i donāt see any practical use of homeassistant.local. I use either local IP or usually rather direct external https address, because if i use local IP address then Visual studio code constantly complains that connection is not secure.
Has @fredrikeās patch been rolled into https://github.com/home-assistant/operating-system/releases/tag/5.13 ?
