Hello guys,
I would like to know if is it possible to install Home Assistant through Windows 8 ?
Thank you all
Have you tried the installation instructions for Windows 10? It should work; you’ll have to install Python first - use the 32 bit version even if you are on a 64 bit Windows build because of some issues with the 64 bit Python.
Thank you for your quick answer rpitera ! Is it possible to install it without using pip ? I am working behind a proxy and I meet some issues
I don’t think so. You may want to look into a Docker install instead.
