Recently received a HA Yellow Rev. 1.3 std kit. RPi CM4 Lite with 2GB (CM4102000). Using a 512 GB HP SSD EX900 Plus M.2 NVMe for storage.
I used rpi-imager to create the Yellow install on a USB drive. Booted of the USB and the HAOS installed in a few minutes. Now it just boots to HAOS with the red and green LEDs on solid. I can ping 8.8.8.8 from HAOS prompt.
Here is the console output after the HAOS install:
[ 179.935287] reboot: Power down
Core: 213 devices, 17 uclasses, devicetree: board
MMC: mmcnr@7e300000: 1, mmc@7e340000: 0
Loading Environment from nowhere... OK
In: serial
Out: serial
Err: serial
Net: eth0: ethernet@7d580000
PCIe BRCM: link down
starting USB...
No working controllers found
Card did not respond to voltage select! : -110
MMC Device 2 not found
no mmc device at slot 2
Device 0: unknown device
starting USB...
USB is stopped. Please issue 'usb start' first.
starting USB...
ethernet@7d580000 Waiting for PHY auto negotiation to complete....... done
BOOTP broadcast 1
BOOTP broadcast 2
DHCP client bound to address 192.168.xx.yy (251 ms)
*** ERROR: `serverip' not set
Cannot autoload with TFTPGET
missing environment variable: pxeuuid
Retrieving file: pxelinux.cfg/01-d8-3a-aa-bb-cc-dd
Retrieving file: pxelinux.cfg/C0A8131D
Retrieving file: pxelinux.cfg/default-arm-bcm283x-rpi
Config file not found
starting USB...
BOOTP broadcast 1
DHCP client bound to address 192.168.xx.yy (0 ms)
HAOS>
Console output has this level of RPi CM firmware:
raspberrypi-firmware soc:firmware: Attached to firmware from 2022-03-24T13:19:26, variant start
I’m at a loss. Help!
