Installation problem homeassistant mosquitto zigbee2mqtt
I’ve tried to install in Docker Home Assistant + Mosquitto + Zigbee2MQTT
Compose file
version: '3.3'
services:
  eclipse-mosquitto:
    container_name: mosquitto
    image: eclipse-mosquitto:latest
    restart: always
    volumes:
      - /media/storage/docker/mosquitto/config:/mosquitto/config
      - /media/storage/docker/mosquitto/data:/mosquitto/data
      - /media/storage/docker/mosquitto/log:/mosquitto/log
    ports:
      - 1883:1883
      - 9001:9001
  zigbee2mqtt:
    container_name: zigbee2mqtt
    image: koenkk/zigbee2mqtt:latest
    restart: always
    volumes:
    - /media/storage/docker/zigbee2mqtt:/app/data
    devices:
    - /dev/serial/by-id/usb-Texas_Instruments_TI_CC2531_USB_CDC___0X00124B000FE7134F-if00:/dev/ttyACM0
    network_mode: host
  homeassistant:
    container_name: home-assistant
    image: homeassistant/home-assistant:stable
    volumes:
      - /media/storage/docker/home-assistant/config:/config
    devices:
      - /dev/ttyACM1:/dev/ttyACM1
    environment:
      - TZ=Europe/Minsk
    restart: always
    ports:
      - 8123:8123`
Blockquote
During the installation I can see messages:
Blockquote
mosquitto exited with code 3
zigbee2mqtt | zigbee2mqtt:error 2019-12-13T11:44:28: Not connected to MQTT server!
zigbee2mqtt | zigbee2mqtt:error 2019-12-13T11:44:38: Not connected to MQTT server!
zigbee2mqtt | zigbee2mqtt:error 2019-12-13T11:44:48: Not connected to MQTT server!
zigbee2mqtt | zigbee2mqtt:error 2019-12-13T11:44:58: Not connected to MQTT server!
zigbee2mqtt | zigbee2mqtt:error 2019-12-13T11:45:08: Not connected to MQTT server!
zigbee2mqtt | zigbee2mqtt:error 2019-12-13T11:45:18: Not connected to MQTT server!
mosquitto | 1576237047: Error: Unable to open config file /mosquitto/config/mosquitto.conf.
mosquitto | 1576237049: Error: Unable to open config file /mosquitto/config/mosquitto.conf.
mosquitto | 1576237050: Error: Unable to open config file /mosquitto/config/mosquitto.conf.
mosquitto | 1576237051: Error: Unable to open config file /mosquitto/config/mosquitto.conf.
mosquitto | 1576237053: Error: Unable to open config file /mosquitto/config/mosquitto.conf.
mosquitto | 1576237056: Error: Unable to open config file /mosquitto/config/mosquitto.conf.
Blockquote
Maybe somebody has this issue and resolve it?
The error message: “mosquitto | 1576237056: Error: Unable to open config file /mosquitto/config/mosquitto.conf” tells you that no file is created for the config.
You need to create a mosquitto.conf file in the following folder on your host:
You can find an example here: https://github.com/eclipse/mosquitto/blob/adb6f3a39d5bb25eb5291d93de6478441351bb64/mosquitto.conf
Had the same issue, by default the folder /mosquitto/config/ on host machine is empty, so no config to start.
