Hello.
I have problem with discovery component, iOS component and notify component.
What dependencies i need to install to run this component?
Thx for help its my first post.
Sorry for my english
2017-06-03 13:33:43 ERROR (MainThread) [homeassistant.setup] Error during setup of component discovery
File "/usr/local/lib/python3.4/dist-packages/homeassistant/setup.py", line 185, in _async_setup_component
result = yield from component.async_setup(hass, processed_config)
File "/usr/lib/python3.4/asyncio/coroutines.py", line 141, in coro
res = func(*args, **kw)
File "/usr/local/lib/python3.4/dist-packages/homeassistant/components/discovery.py", line 74, in async_setup
from netdisco.discovery import NetworkDiscovery
File "/root/.homeassistant/deps/netdisco/discovery.py", line 6, in <module>
from .ssdp import SSDP
File "/root/.homeassistant/deps/netdisco/ssdp.py", line 11, in <module>
from netdisco.util import etree_to_dict, interface_addresses
File "/root/.homeassistant/deps/netdisco/util.py", line 4, in <module>
import netifaces
ImportError: /root/.homeassistant/deps/netifaces.cpython-34m.so: wrong ELF class: ELFCLASS32
2017-06-03 13:33:42 ERROR (MainThread) [homeassistant.setup] Error during setup of component zeroconf
File "/usr/local/lib/python3.4/dist-packages/homeassistant/setup.py", line 188, in _async_setup_component
None, component.setup, hass, processed_config)
File "/usr/lib/python3.4/asyncio/futures.py", line 388, in __iter__
yield self # This tells Task to wait for completion.
File "/usr/lib/python3.4/asyncio/tasks.py", line 286, in _wakeup
value = future.result()
File "/usr/lib/python3.4/asyncio/futures.py", line 277, in result
raise self._exception
File "/usr/lib/python3.4/concurrent/futures/thread.py", line 54, in run
File "/usr/local/lib/python3.4/dist-packages/homeassistant/components/zeroconf.py", line 31, in setup
from zeroconf import Zeroconf, ServiceInfo
File "/root/.homeassistant/deps/zeroconf.py", line 38, in <module>
import netifaces
