Installation Problem - Proxmox VM
Hello, unfortunately I get the following error message when installing on a Proxmox Debian11 VM.
from Install Script
sudo bash -c "$(wget -qLO - https://raw.githubusercontent.com/Kanga-Who/home-assistant/master/hassos_install.sh)"
bash: Zeile 62: pvesm: Kommando nicht gefunden.
numfmt: ungültige Zahl: „failure“
That script is a different script. This is to install supervised on debian 11:
wget https://github.com/home-assistant/supervised-installer/releases/latest/download/homeassistant-supervised.deb
dpkg -i homeassistant-supervised.deb
thanks … great
The script does work, @francisp is incorrect, you are just using the wrong one. I have already responded to you in the guide thread you posted in before making this post.
The script is indeed working flawlessly :+1:t3:
It seems more about quantity but just little about quality… :rofl:
