Same problem here. Wrote the image twice. RPI3B+ boots, reboots 2 times but nothing. I can ping the device but that’s it. No ports open.
In the end connected it to a display and logged in. Whatever command I tried to run it complained homeassistant was not running.
I’ve now install raspbian 64bit and am trying with with hassio_install. Got a docker running but again, that’s about it…
# docker ps
CONTAINER ID IMAGE COMMAND CREATED STATUS PORTS NAMES
3e718d9106ee homeassistant/armhf-hassio-supervisor "python3 -m hassio" 22 minutes ago Up 12 minutes hassio_supervisor
I’ve actually got the basic HA working on the B+ under Raspbian Stretch (non-Lite), by following the manual installation instructions, but seeing how much easier configuration and addon management is with hass.io it feels a bit like you’re left out of the party.
Did you try to connect a display to the pie to check if the logs might give some information?
On my Pi 3 B I had problems with one of my SD cards using the hassOS image, while the card worked perfectly fine with the resinOS image. After switching the card the setup finished without problems.
How do you check the logs. When I tried to login I was in some sort of limited shell. I only could run some homeassistant commands which all failed as HA was not running.
For some reason, just plugging it into the display made it work, and now I’ve got HASS.io setup and running. (Could it be some server somewhere being overloaded?)
Now, is there some way I can move to a new WiFi network without reflashing the image?
