I do not get home assitant installed. it will remain on the next notification. wlan0 link is not ready. what is the problem???
Perhaps it cannot connect to your wireless network.
I think so too. but I can not find where to adjust that.
What version are you installing?
What are you installing it on? I assume from the error it is not Windows.
What instructions are you using?
I install home assitant on an rp3 b +. the version is 3.2.7. I have a screen on it. and almost at the last of the installation it gives this message. I have now connected it with a LAN cable. I can also recover through the browser. but the installation is not finished.
OK I just installed Hassio on Raspian Lite on my rp3 b+ yesterday.
Do you plan on keeping t connected to Ethernet? If so, you can safely ignore the error.
There are many ways to install Home Assistant and its variants on that device.
Do you have a link to the installation instructions you followed?
I chose not to install the HassOS variant due to my previous experiences with it in a virtual machine.
I am still beginning with the rp. I have the instructions on the site of home assitant. Via the browser can i see the logo of home assintant. with the text below that it takes another 20 minutes. i have waiting voor one hour but nothing hapens.
Try refreshing your browser or close the browser & reopen. The spped of installation depends somewhat on your Internet connection.
It appears you are trying either option 1 or 2 below.
Installation options:
HassOS- 32 bit or 64-bit? https://www.home-assistant.io/getting-started/
Hassio on Raspian (32 bit & 64 bit) https://github.com/home-assistant/hassio-build/tree/master/install#install-hassio
Hassbian (old?) https://www.home-assistant.io/docs/installation/hassbian/installation/
Docker on Raspian https://www.home-assistant.io/docs/installation/docker/
Virtual Environment on Raspian https://www.home-assistant.io/docs/installation/virtualenv/
sorry for the late response. but it works. I had to erase everything from the explore. then enter the url and it works. thanks for your help
