I just installed on Pi. All seems to be working except when I add an object(switch), it is not showing up on the panel. Doesn’t seem to matter where i place the code in the configuration.yaml file. Any assistance would be appreciated
Please format the code you posted using “`” so it retains its formatting. That way we can help troubleshoot. Also, please post any relevant errors you’re getting.
Is your code really indented 4 spaces under the switch or are you still struggling to get it to format correctly? It should only be indented two spaces.
It ws indented 4 spaces to match a Youtube video instruction. I changed this to two spaces and the switch now shows up. I am now trying to figure out how to test mqtt using Mosquito install app on Home Assist
